LG Refrigerator Light Replacement
  1. LG Refrigerator Light Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Light Replacement, Open the doors: step 2, image 1 of 3 LG Refrigerator Light Replacement, Open the doors: step 2, image 2 of 3 LG Refrigerator Light Replacement, Open the doors: step 2, image 3 of 3
    • Open both refrigerator doors fully.
  3. LG Refrigerator Light Replacement, Remove the shelves: step 3, image 1 of 3 LG Refrigerator Light Replacement, Remove the shelves: step 3, image 2 of 3 LG Refrigerator Light Replacement, Remove the shelves: step 3, image 3 of 3
    • Lift up the front edge of the shelf to release it.
    • Unhook the shelf and remove it.
    • Repeat the last two steps for each shelf you wish to remove.
  4. LG Refrigerator Light Replacement, Remove the light unit screws: step 4, image 1 of 1
    • Use a Phillips screwdriver to remove the screws that secure the light unit.
  5. LG Refrigerator Light Replacement, Lower the light unit: step 5, image 1 of 2 LG Refrigerator Light Replacement, Lower the light unit: step 5, image 2 of 2
    • With both hands, pull down the front edge of the light unit until it pops free.
    • Don't try to fully remove the light unit yet, as it is still connected to the refrigerator by some wires.
  6. LG Refrigerator Light Replacement, Disconnect the light unit: step 6, image 1 of 3 LG Refrigerator Light Replacement, Disconnect the light unit: step 6, image 2 of 3 LG Refrigerator Light Replacement, Disconnect the light unit: step 6, image 3 of 3
    • Pinch the light unit connector to release it and pull it out straight to disconnect.
    • Remove the light unit.
  7. LG Refrigerator Light Replacement, Remove the light cover: step 7, image 1 of 3 LG Refrigerator Light Replacement, Remove the light cover: step 7, image 2 of 3 LG Refrigerator Light Replacement, Remove the light cover: step 7, image 3 of 3
    • Use a spudger to pry and release the two clips on the rear edge of the light.
  8. LG Refrigerator Light Replacement: step 8, image 1 of 3 LG Refrigerator Light Replacement: step 8, image 2 of 3 LG Refrigerator Light Replacement: step 8, image 3 of 3
    • Use a spudger to pry and release the sides of the light cover from the light base.
  9. LG Refrigerator Light Replacement: step 9, image 1 of 1
    • Separate the light base from the light cover.
  10. LG Refrigerator Light Replacement, Remove the light module: step 10, image 1 of 1
    • Use a Philips head driver to remove the screws securing the light module.
  11. LG Refrigerator Light Replacement: step 11, image 1 of 2 LG Refrigerator Light Replacement: step 11, image 2 of 2
    • Lift the light module out of the light base and remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
38,910 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,235 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 123
All Time: 1,395
