LG Risio Motherboard Replacement
  1. LG Risio Motherboard Replacement, Back Panel: step 1, image 1 of 2 LG Risio Motherboard Replacement, Back Panel: step 1, image 2 of 2
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. LG Risio Motherboard Replacement, Battery: step 2, image 1 of 1
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. LG Risio Motherboard Replacement, Midframe: step 3, image 1 of 1
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. LG Risio Motherboard Replacement: step 4, image 1 of 2 LG Risio Motherboard Replacement: step 4, image 2 of 2
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. LG Risio Motherboard Replacement: step 5, image 1 of 3 LG Risio Motherboard Replacement: step 5, image 2 of 3 LG Risio Motherboard Replacement: step 5, image 3 of 3
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. LG Risio Motherboard Replacement: step 6, image 1 of 1
    • Using your hand, pick up the midframe to separate it from the phone.
  7. LG Risio Motherboard Replacement, Motherboard: step 7, image 1 of 2 LG Risio Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up.
    • The screen connector is the part that has P5 written on it.
  8. LG Risio Motherboard Replacement: step 8, image 1 of 1
    • On the side with the screen connector, pull the two tabs away from the device.
    • Use the plastic opening tool to lift the motherboard starting on the bottom right corner and pulling upwards.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 277
