LG Rumor Touch Motherboard Replacement
  1. LG Rumor Touch Motherboard Replacement, Battery: step 1, image 1 of 1
    • Remove the phone's back cover by placing your thumb the above charging port, located at the bottom of the phone, and sliding the back cover upward.
  2. LG Rumor Touch Motherboard Replacement: step 2, image 1 of 2 LG Rumor Touch Motherboard Replacement: step 2, image 2 of 2
    • Gently pry the battery out of the phone with the spudger.
  3. LG Rumor Touch Motherboard Replacement, Inner Shell: step 3, image 1 of 1
    • Unscrew the 5 #1 5mm screws.
  4. LG Rumor Touch Motherboard Replacement: step 4, image 1 of 1
    • Lift the inner shell from the phone.
  5. LG Rumor Touch Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Unscrew two 2mm #00 screws located behind the white serial code sticker.
  6. LG Rumor Touch Motherboard Replacement: step 6, image 1 of 1
    • Disconnect the ribbon found in the middle of the phone
    • Gently pull the ribbon out of the way.
  7. LG Rumor Touch Motherboard Replacement: step 7, image 1 of 2 LG Rumor Touch Motherboard Replacement: step 7, image 2 of 2
    • Slide open the phone, revealing the QWERTY keyboard.
  8. LG Rumor Touch Motherboard Replacement: step 8, image 1 of 2 LG Rumor Touch Motherboard Replacement: step 8, image 2 of 2
    • Carefully push the mother board through by pressing into the keyboard.
  9. LG Rumor Touch Motherboard Replacement: step 9, image 1 of 1
    • The mother board will fall out of the back along with the silicon keyboard pad.
Jose Rivas
134 Reputation
1 Guide authored
Cal Poly, Team 17-2, Forte Winter 2014 Member of Cal Poly, Team 17-2, Forte Winter 2014
CPSU-FORTE-W14S17G2
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 8
All Time: 736
