LG Spectrum Camera Replacement
  1. LG Spectrum Camera Replacement, Battery: step 1, image 1 of 2 LG Spectrum Camera Replacement, Battery: step 1, image 2 of 2
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
  2. LG Spectrum Camera Replacement: step 2, image 1 of 1
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
  3. LG Spectrum Camera Replacement, Camera: step 3, image 1 of 2 LG Spectrum Camera Replacement, Camera: step 3, image 2 of 2
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnet board to keep the screws in one place.
  4. LG Spectrum Camera Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
  5. LG Spectrum Camera Replacement: step 5, image 1 of 2 LG Spectrum Camera Replacement: step 5, image 2 of 2
    • Remove the camera by gently lifting the film that is attached to it from motherboard with the plastic opening tool.
  6. LG Spectrum Camera Replacement: step 6, image 1 of 1
    • Use the plastic opening tool, or your hand, to pull up on the camera and remove it from the motherboard.
Aiman Sallam
506 Reputation
5 Guides authored
USF Tampa, Team 1-4, Sullivan Spring 2016 Member of USF Tampa, Team 1-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G4
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 170
