LG Spectrum Sim/SD Port Replacement
  1. LG Spectrum Sim/SD Port Replacement, Battery: step 1, image 1 of 2 LG Spectrum Sim/SD Port Replacement, Battery: step 1, image 2 of 2
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
  2. LG Spectrum Sim/SD Port Replacement: step 2, image 1 of 1
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
  3. LG Spectrum Sim/SD Port Replacement, Sim/SD Port: step 3, image 1 of 2 LG Spectrum Sim/SD Port Replacement, Sim/SD Port: step 3, image 2 of 2
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnetic mat to keep the screws in one place.
  4. LG Spectrum Sim/SD Port Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
  5. LG Spectrum Sim/SD Port Replacement: step 5, image 1 of 1
    • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
  6. LG Spectrum Sim/SD Port Replacement: step 6, image 1 of 1
    • Hook the plastic opening tool underneath the plate and gently lift it up.
  7. LG Spectrum Sim/SD Port Replacement: step 7, image 1 of 1
    • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
Aiman Sallam
506 Reputation
5 Guides authored
USF Tampa, Team 1-4, Sullivan Spring 2016 Member of USF Tampa, Team 1-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G4
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 315
