LG Stylo 2 Display Replacement
  1. LG Stylo 2 Display Replacement, Battery: step 1, image 1 of 3 LG Stylo 2 Display Replacement, Battery: step 1, image 2 of 3 LG Stylo 2 Display Replacement, Battery: step 1, image 3 of 3
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
  2. LG Stylo 2 Display Replacement: step 2, image 1 of 3 LG Stylo 2 Display Replacement: step 2, image 2 of 3 LG Stylo 2 Display Replacement: step 2, image 3 of 3
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
  3. LG Stylo 2 Display Replacement, Rear Camera: step 3, image 1 of 3 LG Stylo 2 Display Replacement, Rear Camera: step 3, image 2 of 3 LG Stylo 2 Display Replacement, Rear Camera: step 3, image 3 of 3
    • Remove the eleven 4mm Phillips #00 screws.
    • Place screws in safe location.
    • Use Plastic opener tool to remove inner case.
    • Gently remove inner case.
  4. LG Stylo 2 Display Replacement: step 4, image 1 of 3 LG Stylo 2 Display Replacement: step 4, image 2 of 3 LG Stylo 2 Display Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use your finger or the opener to flip the flex cable shown in red box.
    • Use the precision tweezers to remove camera carefully.
  5. LG Stylo 2 Display Replacement, Motherboard: step 5, image 1 of 3 LG Stylo 2 Display Replacement, Motherboard: step 5, image 2 of 3 LG Stylo 2 Display Replacement, Motherboard: step 5, image 3 of 3
    • Gently flip the cables(shown in red boxes) using the opener tool.
    • Gently remove the motherboard itself.
    • Place motherboard on a soft surface to not damage it.
  6. LG Stylo 2 Display Replacement, Display: step 6, image 1 of 3 LG Stylo 2 Display Replacement, Display: step 6, image 2 of 3 LG Stylo 2 Display Replacement, Display: step 6, image 3 of 3
    • Carefully remove the Vibrator.
    • Carefully remove the sensor.
    • Prepare to remove film.
  7. LG Stylo 2 Display Replacement: step 7, image 1 of 3 LG Stylo 2 Display Replacement: step 7, image 2 of 3 LG Stylo 2 Display Replacement: step 7, image 3 of 3
    Buy
    • Use the tweezers to peel the film off carefully.
    • Use the tweezers to remove the headphone jack gently.
    • Place all three devices in a safe, known, location.
15 other people completed this guide.
Devon Barber
994 Reputation
5 Guides authored
USF Tampa, Team S11-G1, Cheng Spring 2018 Member of USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
4 Members
10 Guides authored
2 Guide Comments
Hello guys
I just replaced the screen for my LG Stylus 2 plus. I got the display off https://www.injuredgadgets.com/lg-stylus...
But after replacing the screen and turning it on only the back light is functioning. I tried reusing the old display and it worked just fine. Is there any suggestions to why this one is not working or is my new screen just a bust ?
Several Genie - Reply
I've got the same problem please help this phone has all my late sons pictures and my daughter's it's a LG Stylo 2
Cody Pinson - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 23
All Time: 6,234
