LG Stylo 2 Motherboard Replacement
  1. LG Stylo 2 Motherboard  Replacement, Battery: step 1, image 1 of 3 LG Stylo 2 Motherboard  Replacement, Battery: step 1, image 2 of 3 LG Stylo 2 Motherboard  Replacement, Battery: step 1, image 3 of 3
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
  2. LG Stylo 2 Motherboard  Replacement: step 2, image 1 of 3 LG Stylo 2 Motherboard  Replacement: step 2, image 2 of 3 LG Stylo 2 Motherboard  Replacement: step 2, image 3 of 3
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
  3. LG Stylo 2 Motherboard  Replacement, Rear Camera: step 3, image 1 of 3 LG Stylo 2 Motherboard  Replacement, Rear Camera: step 3, image 2 of 3 LG Stylo 2 Motherboard  Replacement, Rear Camera: step 3, image 3 of 3
    • Remove the eleven 4mm Phillips #00 screws.
    • Place screws in safe location.
    • Use Plastic opener tool to remove inner case.
    • Gently remove inner case.
  4. LG Stylo 2 Motherboard  Replacement: step 4, image 1 of 3 LG Stylo 2 Motherboard  Replacement: step 4, image 2 of 3 LG Stylo 2 Motherboard  Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use your finger or the opener to flip the flex cable shown in red box.
    • Use the precision tweezers to remove camera carefully.
  5. LG Stylo 2 Motherboard  Replacement, Motherboard: step 5, image 1 of 3 LG Stylo 2 Motherboard  Replacement, Motherboard: step 5, image 2 of 3 LG Stylo 2 Motherboard  Replacement, Motherboard: step 5, image 3 of 3
    • Gently flip the cables(shown in red boxes) using the opener tool.
    • Gently remove the motherboard itself.
    • Place motherboard on a soft surface to not damage it.
Devon Barber
994 Reputation
5 Guides authored
USF Tampa, Team S11-G1, Cheng Spring 2018 Member of USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
4 Members
10 Guides authored
1 Guide Comment
Charging retain 2.1
Kashif Kashi - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 2,501
