LG Stylo 2 Plus Rear Camera Replacement
  1. LG Stylo 2 Plus Rear Camera Replacement, Rear Case: step 1, image 1 of 3 LG Stylo 2 Plus Rear Camera Replacement, Rear Case: step 1, image 2 of 3 LG Stylo 2 Plus Rear Camera Replacement, Rear Case: step 1, image 3 of 3
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
  2. LG Stylo 2 Plus Rear Camera Replacement, Battery: step 2, image 1 of 3 LG Stylo 2 Plus Rear Camera Replacement, Battery: step 2, image 2 of 3 LG Stylo 2 Plus Rear Camera Replacement, Battery: step 2, image 3 of 3
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
  3. LG Stylo 2 Plus Rear Camera Replacement, Mid-Frame: step 3, image 1 of 2 LG Stylo 2 Plus Rear Camera Replacement, Mid-Frame: step 3, image 2 of 2
    • Using the JIS #000 screwdriver, remove the eleven 4mm screws around the mid-frame.
  4. LG Stylo 2 Plus Rear Camera Replacement: step 4, image 1 of 2 LG Stylo 2 Plus Rear Camera Replacement: step 4, image 2 of 2
    • Insert the metal spudger in the dimple at the base of the cover.
    • Pry upward, removing the mid-frame from the phone.
  5. LG Stylo 2 Plus Rear Camera Replacement, Rear Camera: step 5, image 1 of 3 LG Stylo 2 Plus Rear Camera Replacement, Rear Camera: step 5, image 2 of 3 LG Stylo 2 Plus Rear Camera Replacement, Rear Camera: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Flip the cover over to show the rear camera unit in the center of the cover.
    • Using the tweezers, carefully grab the rear camera unit and pull directly upward, removing the unit from the cover housing.
Noah Kehm
241 Reputation
3 Guides authored
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Member of UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 124
