LG Stylo 3 Plus Display Assembly Replacement
  1. LG Stylo 3 Plus Display Assembly Replacement, Back Cover: step 1, image 1 of 3 LG Stylo 3 Plus Display Assembly Replacement, Back Cover: step 1, image 2 of 3 LG Stylo 3 Plus Display Assembly Replacement, Back Cover: step 1, image 3 of 3
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
  2. LG Stylo 3 Plus Display Assembly Replacement, Battery: step 2, image 1 of 3 LG Stylo 3 Plus Display Assembly Replacement, Battery: step 2, image 2 of 3 LG Stylo 3 Plus Display Assembly Replacement, Battery: step 2, image 3 of 3
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
  3. LG Stylo 3 Plus Display Assembly Replacement, Rear Camera: step 3, image 1 of 3 LG Stylo 3 Plus Display Assembly Replacement, Rear Camera: step 3, image 2 of 3 LG Stylo 3 Plus Display Assembly Replacement, Rear Camera: step 3, image 3 of 3
    • Remove the twelve 4mm screws using the Phillips #000 screwdriver.
    • Use the plastic opening tool to remove the inner case.
    • Carefully remove the inner case.
  4. LG Stylo 3 Plus Display Assembly Replacement: step 4, image 1 of 2 LG Stylo 3 Plus Display Assembly Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use your fingernail or the plastic opening tool to flip the flex cable.
    • Use the precision tweezers to carefully grasp and pull out the camera.
  5. LG Stylo 3 Plus Display Assembly Replacement, Front Camera: step 5, image 1 of 2 LG Stylo 3 Plus Display Assembly Replacement, Front Camera: step 5, image 2 of 2
    Buy
    • Carefully flip open the flex cable box with the plastic opening tool.
    • Using precision tweezers, carefully lift the front camera off the device.
  6. LG Stylo 3 Plus Display Assembly Replacement, Motherboard: step 6, image 1 of 3 LG Stylo 3 Plus Display Assembly Replacement, Motherboard: step 6, image 2 of 3 LG Stylo 3 Plus Display Assembly Replacement, Motherboard: step 6, image 3 of 3
    • Gently flip open the flex cable box using a blue plastic opening tool.
    • Carefully remove the motherboard with your hands or a blue plastic opening tool.
    • Make sure all parts are secure while taking out motherboard.
  7. LG Stylo 3 Plus Display Assembly Replacement, Headphone Jack: step 7, image 1 of 2 LG Stylo 3 Plus Display Assembly Replacement, Headphone Jack: step 7, image 2 of 2
    • Remove the headphone jack.
  8. LG Stylo 3 Plus Display Assembly Replacement, Display Assembly: step 8, image 1 of 1
    • The remaining component is your complete display assembly.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 21
All Time: 1,224
