LG TV 49SJ8000 - WiFi module disassembly
  1. LG TV 49SJ8000 - WiFi module disassembly, LG TV 49SJ8000 - WiFi module disassembly: step 1, image 1 of 1
    • Place the display on a soft surface in order to help prevent scratches and/or breaking the display.
    • Remove the 4 Phillips screws that hold the stand in place (if installed).
    • Remove all screws from the rear panel.
    • There are two screws near to the input and output connectors.
    • On the lower part of the TV (next to the speakers) there are two additional screws that need to be removed.
  2. LG TV 49SJ8000 - WiFi module disassembly: step 2, image 1 of 1
    • With the panel removed, it's possible to visualize the boards and its connections.
    • To the left, there is the power supply, which supplies power to the TV.
    • To the right, there is the logic board.
    • On the lower section you can locate both speakers.
    • Between both speakers you can find the Wi-Fi and Bluetooth module.
  3. LG TV 49SJ8000 - WiFi module disassembly: step 3, image 1 of 2 LG TV 49SJ8000 - WiFi module disassembly: step 3, image 2 of 2
    • To remove the Wi-Fi and Bluetooth module, there is only one screw holding the entirety of the structure.
  4. LG TV 49SJ8000 - WiFi module disassembly: step 4, image 1 of 2 LG TV 49SJ8000 - WiFi module disassembly: step 4, image 2 of 2
    • Wi-Fi module removed.
    • If your TV shows the message Device Connected/Device Disconnected, Wi-Fi not working or Magic remote not working, it's possible that there is a bad connection on the module.
    • Remove the flex cables carefully and install them once again.
    • In order to remove the flex cable, there is a little tab that needs to be lifted.
To reassemble your device, follow this instructions in inverse order.
6 other people completed this guide.
Special thanks to these translators:
pt en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Diogo Cordova
247 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 20
Past 7 Days: 95
Past 30 Days: 430
All Time: 10,236
