LG Thrill 4G Motherboard Replacement
  1. LG Thrill 4G Motherboard Replacement, Back Cover Removal: step 1, image 1 of 2 LG Thrill 4G Motherboard Replacement, Back Cover Removal: step 1, image 2 of 2
    • Pry open the back cover by using a fingernail or a plastic opening tool.
    • There is a small notch at the bottom of the cover for easy removal.
  2. LG Thrill 4G Motherboard Replacement, Battery Removal: step 2, image 1 of 2 LG Thrill 4G Motherboard Replacement, Battery Removal: step 2, image 2 of 2
    • Remove the battery from the phone.
    • There is a small ledge located at the bottom of the battery for easy removal.
  3. LG Thrill 4G Motherboard Replacement, Screw Removal: step 3, image 1 of 1
    • Remove the three Philips #00 screws from the bottom of the phone.
    • Two 5.5 mm screws
    • One 4 mm screw
  4. LG Thrill 4G Motherboard Replacement, Speaker Removal: step 4, image 1 of 2 LG Thrill 4G Motherboard Replacement, Speaker Removal: step 4, image 2 of 2
    • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
  5. LG Thrill 4G Motherboard Replacement, Buttons: step 5, image 1 of 1
    • Remove the three buttons from the side and the top of the phone.
    • Power button
    • Volume button
    • 3D camera button
  6. LG Thrill 4G Motherboard Replacement: step 6, image 1 of 3 LG Thrill 4G Motherboard Replacement: step 6, image 2 of 3 LG Thrill 4G Motherboard Replacement: step 6, image 3 of 3
    • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
    • This loosens both the HDMI and USB covers for easy removal.
    • USB Cover
    • HDMI Cover
  7. LG Thrill 4G Motherboard Replacement: step 7, image 1 of 1
    • Remove the six Phillips #00 screws within the mid-cover bezel.
  8. LG Thrill 4G Motherboard Replacement, Ribbon Cable Disconnection: step 8, image 1 of 3 LG Thrill 4G Motherboard Replacement, Ribbon Cable Disconnection: step 8, image 2 of 3 LG Thrill 4G Motherboard Replacement, Ribbon Cable Disconnection: step 8, image 3 of 3
    • Utilize a spudger or plastic opening tool and gently disconnect the ribbon cable that is attached to the black micro-SIM card board.
  9. LG Thrill 4G Motherboard Replacement, SD/SIM Card Board Removal: step 9, image 1 of 3 LG Thrill 4G Motherboard Replacement, SD/SIM Card Board Removal: step 9, image 2 of 3 LG Thrill 4G Motherboard Replacement, SD/SIM Card Board Removal: step 9, image 3 of 3
    • Carefully pry the board up to detach it from its place in the phone.
    • Make sure to pry off the small tab connected to the camera unit as well.
  10. LG Thrill 4G Motherboard Replacement, Motherboard: step 10, image 1 of 2 LG Thrill 4G Motherboard Replacement, Motherboard: step 10, image 2 of 2
    • Use a plastic opening tool or spudger to gently disconnect the ribbon cables connected to the motherboard.
    • Disconnect the antenna cable from the bottom right corner of the motherboard.
  11. LG Thrill 4G Motherboard Replacement: step 11, image 1 of 2 LG Thrill 4G Motherboard Replacement: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • Use a spudger or pair of tweezers to grab the top left corner of the motherboard and gently lift it out, taking care to not damage any of the ribbon cables when removing.
2 other people completed this guide.
Luis Mena
270 Reputation
2 Guides authored
USF Tampa, Team 1-6, Blackwell Winter 2015 Member of USF Tampa, Team 1-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G6
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 512
