LG Tone Pro HBS-760 Speaker Replacement
  1. LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: step 1, image 1 of 3 LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: step 1, image 2 of 3 LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: step 1, image 3 of 3
    • Locate the right and left side speaker where the hidden screw is located and remove the rubber piece covering the screw.
  2. LG Tone Pro HBS-760 Speaker  Replacement, Remove Hidden Screw: step 2, image 1 of 2 LG Tone Pro HBS-760 Speaker  Replacement, Remove Hidden Screw: step 2, image 2 of 2
    • Using a Philips #00 screwdriver, remove the hidden screws from both sides.
  3. LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: step 3, image 1 of 3 LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: step 3, image 2 of 3 LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: step 3, image 3 of 3
    • Use a guitar pick or any opening tool to pry open the housing for the side you want to replace the speaker.
  4. LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: step 4, image 1 of 3 LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: step 4, image 2 of 3 LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: step 4, image 3 of 3
    • Right side can be de-soldered right away but the left side speaker solder connection to the board is covered by rubber material which needs to be removed first before it can be de-soldered.
  5. LG Tone Pro HBS-760 Speaker  Replacement, Replace Speakers: step 5, image 1 of 1
    • Once the speakers have been de-soldered, replace with new ones.
2 other people completed this guide.
Faizan Naveed
3,294 Reputation
8 Guides authored
Mobile Device Repair Factory Member of Mobile Device Repair Factory
Business
1 Member
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 1,547
