LG Tribute 5 Motherboard Replacement
  1. LG Tribute 5 Motherboard Replacement, Battery: step 1, image 1 of 2 LG Tribute 5 Motherboard Replacement, Battery: step 1, image 2 of 2
    • Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
  2. LG Tribute 5 Motherboard Replacement: step 2, image 1 of 3 LG Tribute 5 Motherboard Replacement: step 2, image 2 of 3 LG Tribute 5 Motherboard Replacement: step 2, image 3 of 3
    • Gently lift the battery out from the compartment.
    • Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
  3. LG Tribute 5 Motherboard Replacement, Motherboard: step 3, image 1 of 3 LG Tribute 5 Motherboard Replacement, Motherboard: step 3, image 2 of 3 LG Tribute 5 Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Remove the nine 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute 5 Motherboard Replacement: step 4, image 1 of 3 LG Tribute 5 Motherboard Replacement: step 4, image 2 of 3 LG Tribute 5 Motherboard Replacement: step 4, image 3 of 3
    • Using an iFixit opening tool, remove the antenna extender located at the bottom.
  5. LG Tribute 5 Motherboard Replacement: step 5, image 1 of 2 LG Tribute 5 Motherboard Replacement: step 5, image 2 of 2
    • Gently remove the mid-frame using an iFixit opening tool as shown.
    • Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
  6. LG Tribute 5 Motherboard Replacement: step 6, image 1 of 2 LG Tribute 5 Motherboard Replacement: step 6, image 2 of 2
    • Using an iFixit opening tool, gently disconnect the rear camera from the top center of the motherboard.
    • Remove the front facing camera from the top right corner of the motherboard.
  7. LG Tribute 5 Motherboard Replacement: step 7, image 1 of 1
    • Gently pull the speaker out from its compartment with the iFixit opening tool.
  8. LG Tribute 5 Motherboard Replacement: step 8, image 1 of 1
    • Disconnect the flex cable from the motherboard with the iFixit opening tool.
  9. LG Tribute 5 Motherboard Replacement: step 9, image 1 of 1
    • Gently pull up and remove the motherboard using the iFixit opening tool.
4 other people completed this guide.
Renee Dawn Nelson
469 Reputation
3 Guides authored
UW Tacoma, Team S1-G6, Cardinal Spring 2019 Member of UW Tacoma, Team S1-G6, Cardinal Spring 2019
UWT-CARDINAL-S19S1G6
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 444
