LG Tribute HD Flex Cable Replacement
  1. LG Tribute HD Flex Cable Replacement, Battery and SD Card: step 1, image 1 of 2 LG Tribute HD Flex Cable Replacement, Battery and SD Card: step 1, image 2 of 2
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. LG Tribute HD Flex Cable Replacement: step 2, image 1 of 2 LG Tribute HD Flex Cable Replacement: step 2, image 2 of 2
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. LG Tribute HD Flex Cable Replacement, Flex Cable: step 3, image 1 of 2 LG Tribute HD Flex Cable Replacement, Flex Cable: step 3, image 2 of 2
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute HD Flex Cable Replacement: step 4, image 1 of 3 LG Tribute HD Flex Cable Replacement: step 4, image 2 of 3 LG Tribute HD Flex Cable Replacement: step 4, image 3 of 3
    • Using a plastic opening tool, remove the antenna extender from the bottom.
  5. LG Tribute HD Flex Cable Replacement: step 5, image 1 of 2 LG Tribute HD Flex Cable Replacement: step 5, image 2 of 2
    • Using your fingers, remove the mid-frame.
  6. LG Tribute HD Flex Cable Replacement: step 6, image 1 of 3 LG Tribute HD Flex Cable Replacement: step 6, image 2 of 3 LG Tribute HD Flex Cable Replacement: step 6, image 3 of 3
    • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard.
    • Remove the cameras from the phone.
  7. LG Tribute HD Flex Cable Replacement: step 7, image 1 of 3 LG Tribute HD Flex Cable Replacement: step 7, image 2 of 3 LG Tribute HD Flex Cable Replacement: step 7, image 3 of 3
    • Using a plastic opening tool, pry up the front facing speaker and remove it from the phone.
  8. LG Tribute HD Flex Cable Replacement: step 8, image 1 of 1
    • Disconnect the LCD from the motherboard with a plastic opening tool.
  9. LG Tribute HD Flex Cable Replacement: step 9, image 1 of 2 LG Tribute HD Flex Cable Replacement: step 9, image 2 of 2
    • Use a plastic opening tool to pry up the motherboard form the display housing.
    • Remove the motherboard from the phone.
  10. LG Tribute HD Flex Cable Replacement: step 10, image 1 of 2 LG Tribute HD Flex Cable Replacement: step 10, image 2 of 2
    • Use your fingers to remove the flex cables from the phone.
Dhruv Patel
273 Reputation
2 Guides authored
USF Tampa, Team S1-G3, Nance Spring 2018 Member of USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Members
20 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 543
