LG Tribute HD Motherboard Replacement
  1. LG Tribute HD Motherboard Replacement, Battery and SD Card: step 1, image 1 of 2 LG Tribute HD Motherboard Replacement, Battery and SD Card: step 1, image 2 of 2
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. LG Tribute HD Motherboard Replacement: step 2, image 1 of 2 LG Tribute HD Motherboard Replacement: step 2, image 2 of 2
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. LG Tribute HD Motherboard Replacement, Motherboard: step 3, image 1 of 2 LG Tribute HD Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute HD Motherboard Replacement: step 4, image 1 of 3 LG Tribute HD Motherboard Replacement: step 4, image 2 of 3 LG Tribute HD Motherboard Replacement: step 4, image 3 of 3
    • Using a plastic opening tool, remove the antenna extender from the mid-frame.
  5. LG Tribute HD Motherboard Replacement: step 5, image 1 of 2 LG Tribute HD Motherboard Replacement: step 5, image 2 of 2
    • Using your fingers, remove the mid-frame.
  6. LG Tribute HD Motherboard Replacement: step 6, image 1 of 3 LG Tribute HD Motherboard Replacement: step 6, image 2 of 3 LG Tribute HD Motherboard Replacement: step 6, image 3 of 3
    • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard and pull out to remove.
  7. LG Tribute HD Motherboard Replacement: step 7, image 1 of 3 LG Tribute HD Motherboard Replacement: step 7, image 2 of 3 LG Tribute HD Motherboard Replacement: step 7, image 3 of 3
    • Using a plastic opening tool, pry up the front facing speaker and remove from the phone.
  8. LG Tribute HD Motherboard Replacement: step 8, image 1 of 1
    • Disconnect the display from the motherboard.
  9. LG Tribute HD Motherboard Replacement: step 9, image 1 of 2 LG Tribute HD Motherboard Replacement: step 9, image 2 of 2
    • Use a plastic opening tool to pry up the motherboard and pull out to remove.
2 other people completed this guide.
Aalia Mohammed
448 Reputation
4 Guides authored
USF Tampa, Team S1-G3, Nance Spring 2018 Member of USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Members
20 Guides authored
One Comment
svp ou peut-on trouver cette carte mère
Mourasilva Silva - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 1,028
