LG Ultimate 2 Digitizer Replacement
  1. LG Ultimate 2 Digitizer Replacement, Battery: step 1, image 1 of 1
    • Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
  2. LG Ultimate 2 Digitizer Replacement: step 2, image 1 of 1
    • Use your hand to pull the plastic cover completely off of the phone.
  3. LG Ultimate 2 Digitizer Replacement: step 3, image 1 of 1
    • Insert the plastic opening tool into the wedge near the bottom of the battery.
    • Lift the battery out.
  4. LG Ultimate 2 Digitizer Replacement, Digitizer: step 4, image 1 of 2 LG Ultimate 2 Digitizer Replacement, Digitizer: step 4, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the 11 mid-frame screws.
  5. LG Ultimate 2 Digitizer Replacement: step 5, image 1 of 2 LG Ultimate 2 Digitizer Replacement: step 5, image 2 of 2
    • Insert the plastic opening tool to start wedging the phone apart.
    • Trace the plastic opening tool along the edge for the entire perimeter of the phone, pulling it apart as you go.
  6. LG Ultimate 2 Digitizer Replacement: step 6, image 1 of 1
    • Use a plastic opening tool or fingernail to separate the zip connector.
    • The zip connector does not detach completely from the phone, but acts as a flap.
  7. LG Ultimate 2 Digitizer Replacement: step 7, image 1 of 1
    • Insert the plastic opening tool between the screen and the base. This may be difficult because of the adhesive, but enough leverage should force an opening.
  8. LG Ultimate 2 Digitizer Replacement: step 8, image 1 of 1
    • Continue moving the plastic opening tool along the edge of the screen, separating the pieces from the adhesive.
    • A hair dryer might be useful to help melt the adhesive.
  9. LG Ultimate 2 Digitizer Replacement: step 9, image 1 of 1
    • Pry the screen off after all pieces have been loosened from the adhesive.
Devin Isenhower
329 Reputation
2 Guides authored
IUPUI, Team S5-G2, Baechle Spring 2018 Member of IUPUI, Team S5-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G2
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 404
