LG V30 Plus Front-Facing Camera Replacement
  1. LG V30 Plus Front-Facing Camera Replacement, Rear Glass: step 1, image 1 of 1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Front-Facing Camera Replacement: step 2, image 1 of 2 LG V30 Plus Front-Facing Camera Replacement: step 2, image 2 of 2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Front-Facing Camera Replacement: step 3, image 1 of 1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
  4. LG V30 Plus Front-Facing Camera Replacement, Motherboard: step 4, image 1 of 2 LG V30 Plus Front-Facing Camera Replacement, Motherboard: step 4, image 2 of 2
    • Remove the ten 4mm screws using the Phillips #00 Screwdriver.
  5. LG V30 Plus Front-Facing Camera Replacement: step 5, image 1 of 3 LG V30 Plus Front-Facing Camera Replacement: step 5, image 2 of 3 LG V30 Plus Front-Facing Camera Replacement: step 5, image 3 of 3
    • Gently push down on the small black tab with a Spudger to release the protective board.
    • Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
    • Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
  6. LG V30 Plus Front-Facing Camera Replacement: step 6, image 1 of 2 LG V30 Plus Front-Facing Camera Replacement: step 6, image 2 of 2
    • Slide an Opening Tool between the lower protective board and the phone to unclip.
    • Slide the tool along the remaining edges of the protective board until it pops off.
  7. LG V30 Plus Front-Facing Camera Replacement: step 7, image 1 of 2 LG V30 Plus Front-Facing Camera Replacement: step 7, image 2 of 2
    • Gently pry each visible ribbon cable away from the motherboard to disconnect them.
  8. LG V30 Plus Front-Facing Camera Replacement: step 8, image 1 of 1
    • Gently remove the motherboard from the phone.
  9. LG V30 Plus Front-Facing Camera Replacement, Battery: step 9, image 1 of 3 LG V30 Plus Front-Facing Camera Replacement, Battery: step 9, image 2 of 3 LG V30 Plus Front-Facing Camera Replacement, Battery: step 9, image 3 of 3
    • Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
    • There may be a strong adhesive under the battery, so work your way around the battery carefully and slowly.
    • Insert Opening Picks if needed to keep the battery elevated.
  10. LG V30 Plus Front-Facing Camera Replacement, Front-Facing Camera: step 10, image 1 of 2 LG V30 Plus Front-Facing Camera Replacement, Front-Facing Camera: step 10, image 2 of 2
    • Use a Spudger to pry away the front-facing camera from the board.
Samuel Jahnke
282 Reputation
2 Guides authored
Cal Poly, Team S1-G3, Maness Spring 2019 Member of Cal Poly, Team S1-G3, Maness Spring 2019
CPSU-MANESS-S19S1G3
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 411
