LG V30 Plus Rear Glass Replacement
  1. LG V30 Plus Rear Glass Replacement, Rear Glass: step 1, image 1 of 1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Rear Glass Replacement: step 2, image 1 of 2 LG V30 Plus Rear Glass Replacement: step 2, image 2 of 2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Rear Glass Replacement: step 3, image 1 of 1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
Geoffrey Smith
395 Reputation
3 Guides authored
Cal Poly, Team S1-G3, Maness Spring 2019 Member of Cal Poly, Team S1-G3, Maness Spring 2019
CPSU-MANESS-S19S1G3
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 1,057
