LG V30 Rear Camera Replacement
Video Overview
  1. LG V30 Rear Camera Replacement, Rear Camera: step 1, image 1 of 3 LG V30 Rear Camera Replacement, Rear Camera: step 1, image 2 of 3 LG V30 Rear Camera Replacement, Rear Camera: step 1, image 3 of 3
    • Insert a SIM card eject tool into the small hole on the right side of the phone to release the SIM card tray from the phone.
    • Pull the SIM card tray out from the phone.
  2. LG V30 Rear Camera Replacement: step 2, image 1 of 2 LG V30 Rear Camera Replacement: step 2, image 2 of 2
    • Use a heat gun to apply heat to the back cover.
  3. LG V30 Rear Camera Replacement: step 3, image 1 of 3 LG V30 Rear Camera Replacement: step 3, image 2 of 3 LG V30 Rear Camera Replacement: step 3, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Use a suction cup to lift up the back cover up.
    • Insert the edge of a plastic card into the space created between the cover and frame.
  4. LG V30 Rear Camera Replacement: step 4, image 1 of 3 LG V30 Rear Camera Replacement: step 4, image 2 of 3 LG V30 Rear Camera Replacement: step 4, image 3 of 3
    • Insert a second card where you have created an opening with the first card and slide it along the bottom edge of the phone.
  5. LG V30 Rear Camera Replacement: step 5, image 1 of 3 LG V30 Rear Camera Replacement: step 5, image 2 of 3 LG V30 Rear Camera Replacement: step 5, image 3 of 3
    • Continue to slide the cards around the remaining three edges to release the adhesive.
  6. LG V30 Rear Camera Replacement: step 6, image 1 of 3 LG V30 Rear Camera Replacement: step 6, image 2 of 3 LG V30 Rear Camera Replacement: step 6, image 3 of 3
    • Remove the back cover.
  7. LG V30 Rear Camera Replacement: step 7, image 1 of 1
    • Remove the ten Phillips #000 screws from the midframe.
  8. LG V30 Rear Camera Replacement: step 8, image 1 of 3 LG V30 Rear Camera Replacement: step 8, image 2 of 3 LG V30 Rear Camera Replacement: step 8, image 3 of 3
    • Using a plastic spudger, pry up the midframe of the phone.
  9. LG V30 Rear Camera Replacement: step 9, image 1 of 2 LG V30 Rear Camera Replacement: step 9, image 2 of 2
    • Remove the midframe.
  10. LG V30 Rear Camera Replacement: step 10, image 1 of 3 LG V30 Rear Camera Replacement: step 10, image 2 of 3 LG V30 Rear Camera Replacement: step 10, image 3 of 3
    • Use the plastic spudger to pry up the four press fit connectors on the top portion of the motherboard.
  11. LG V30 Rear Camera Replacement: step 11, image 1 of 3 LG V30 Rear Camera Replacement: step 11, image 2 of 3 LG V30 Rear Camera Replacement: step 11, image 3 of 3
    • Pry up the speaker panel with a plastic spudger and remove it from the phone.
  12. LG V30 Rear Camera Replacement: step 12, image 1 of 3 LG V30 Rear Camera Replacement: step 12, image 2 of 3 LG V30 Rear Camera Replacement: step 12, image 3 of 3
    • Use a spudger to pry up the two press fit connectors on the bottom portion of the midframe.
  13. LG V30 Rear Camera Replacement: step 13, image 1 of 3 LG V30 Rear Camera Replacement: step 13, image 2 of 3 LG V30 Rear Camera Replacement: step 13, image 3 of 3
    • Use a spudger to pry up the motherboard and lift it out of the phone's frame.
  14. LG V30 Rear Camera Replacement: step 14, image 1 of 3 LG V30 Rear Camera Replacement: step 14, image 2 of 3 LG V30 Rear Camera Replacement: step 14, image 3 of 3
    • Flip over the motherboard.
    • Using a plastic spudger, pry up the press fit connector for the first camera.
  15. LG V30 Rear Camera Replacement: step 15, image 1 of 2 LG V30 Rear Camera Replacement: step 15, image 2 of 2
    Buy
    • Remove the camera with a pair of ESD safe tweezers.
  16. LG V30 Rear Camera Replacement: step 16, image 1 of 3 LG V30 Rear Camera Replacement: step 16, image 2 of 3 LG V30 Rear Camera Replacement: step 16, image 3 of 3
    • Pry up the second camera with a spudger.
    • The press fit connector has already been disconnected, but the camera module is still lightly adhered to the motherboard.
    • Remove the second camera with a pair of tweezers.
2 other people completed this guide.
Witrigs
70,729 Reputation
377 Guides authored
1 Guide Comment
Does this make it no longer waterproof?
Rob Hoover - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 21
All Time: 2,623
