LG V50 ThinQ Speaker & Charging Port Replacement
  1. LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: step 1, image 1 of 3 LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: step 1, image 2 of 3 LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: step 1, image 3 of 3
    • Flip the phone over, so that the back of the phone is facing you.
    • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Speaker & Charging Port Replacement: step 2, image 1 of 3 LG V50 ThinQ Speaker & Charging Port Replacement: step 2, image 2 of 3 LG V50 ThinQ Speaker & Charging Port Replacement: step 2, image 3 of 3
    • With the back side open, remove all 12 1 mm Phillips #000 screws.
    • Remember to keep the screws in a safe place for reassembly later!
  3. LG V50 ThinQ Speaker & Charging Port Replacement: step 3, image 1 of 3 LG V50 ThinQ Speaker & Charging Port Replacement: step 3, image 2 of 3 LG V50 ThinQ Speaker & Charging Port Replacement: step 3, image 3 of 3
    • Remove the two brackets that are covering internal components.
  4. LG V50 ThinQ Speaker & Charging Port Replacement: step 4, image 1 of 3 LG V50 ThinQ Speaker & Charging Port Replacement: step 4, image 2 of 3 LG V50 ThinQ Speaker & Charging Port Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the battery from the phone by removing the battery connection from the connector port.
    • Disconnect the orange cable by pulling the connector up with your fingers.
    • Pull up with tweezers on the end of the white wire to disconnect it from the two circuit boards.
    • Pull up with tweezers on the dark orange cable to disconnect it.
  5. LG V50 ThinQ Speaker & Charging Port Replacement: step 5, image 1 of 3 LG V50 ThinQ Speaker & Charging Port Replacement: step 5, image 2 of 3 LG V50 ThinQ Speaker & Charging Port Replacement: step 5, image 3 of 3
    • Take out the SIM card by using the SIM head and pushing into the SIM ejector slot.
    • Disconnect the orange panel nearby the SIM slot from the circuit board.
    • Pull up from below the circuit board on the top, next to the CMOS battery to remove the upper circuiting from the phone.
  6. LG V50 ThinQ Speaker & Charging Port Replacement: step 6, image 1 of 3 LG V50 ThinQ Speaker & Charging Port Replacement: step 6, image 2 of 3 LG V50 ThinQ Speaker & Charging Port Replacement: step 6, image 3 of 3
    • Pull up from the right of the metallic cover piece inside of the bottom right of the phone.
    • Remove the metallic piece's base from the board.
    • Make the cubic piece moveable by wiggling under it with an opening pick or spudger.
  7. LG V50 ThinQ Speaker & Charging Port Replacement: step 7, image 1 of 1
    • Remove bottom circuiting, the speaker system is a part of the bottom circuit board.
William Martin
231 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 191
