LG VX4400 Screen Replacement
  1. LG VX4400 Screen Replacement, Screen: step 1, image 1 of 2 LG VX4400 Screen Replacement, Screen: step 1, image 2 of 2
    • Remove the four rubber stoppers around the main screen using the pointed end of the spudger.
  2. LG VX4400 Screen Replacement: step 2, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the four screws that were under the rubber stoppers.
  3. LG VX4400 Screen Replacement: step 3, image 1 of 3 LG VX4400 Screen Replacement: step 3, image 2 of 3 LG VX4400 Screen Replacement: step 3, image 3 of 3
    • Use a plastic opening tool to pry the top end of the phone open.
    • Use a second plastic opening tool to slide down the gap and pry open the case while prying the top panel with the first plastic opening tool.
    • Use the same method on the opposite side of the phone.
  4. LG VX4400 Screen Replacement: step 4, image 1 of 2 LG VX4400 Screen Replacement: step 4, image 2 of 2
    • Remove plastic screen panel to reveal the internal components.
  5. LG VX4400 Screen Replacement: step 5, image 1 of 3 LG VX4400 Screen Replacement: step 5, image 2 of 3 LG VX4400 Screen Replacement: step 5, image 3 of 3
    • Remove the screen board by lifting it away from the phone.
    • Remove the speaker by prying with the spudger.
  6. LG VX4400 Screen Replacement: step 6, image 1 of 3 LG VX4400 Screen Replacement: step 6, image 2 of 3 LG VX4400 Screen Replacement: step 6, image 3 of 3
    • Press out the plastic screen gently.
Nico Chiarito
22 Reputation
5 Guides authored
Cal Poly, Team 8-47, Regan Winter 2010 Member of Cal Poly, Team 8-47, Regan Winter 2010
CPSU-REGAN-W10S8G47
5 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 2,609
