LG VX4500 Speaker Replacement
  1. LG VX4500 Speaker Replacement, Battery: step 1, image 1 of 1
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 Speaker Replacement: step 2, image 1 of 2 LG VX4500 Speaker Replacement: step 2, image 2 of 2
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 Speaker Replacement, Rear Cover: step 3, image 1 of 1
    • Remove the rubber grommet using a spudger.
  4. LG VX4500 Speaker Replacement: step 4, image 1 of 1
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. LG VX4500 Speaker Replacement: step 5, image 1 of 3 LG VX4500 Speaker Replacement: step 5, image 2 of 3 LG VX4500 Speaker Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • When removing back cover, be careful not to break the speaker wires.
    • Using an Opening Tool, carefully pry off the back cover.
    • Using tweezers, gently pull the speaker wires out.
  6. LG VX4500 Speaker Replacement: step 6, image 1 of 1
    • Separate the two halves.
  7. LG VX4500 Speaker Replacement, Speaker: step 7, image 1 of 2 LG VX4500 Speaker Replacement, Speaker: step 7, image 2 of 2
    • Take top half of phone and pry up speaker using the Spudger.
  8. LG VX4500 Speaker Replacement: step 8, image 1 of 1
    • Lift out speaker.
David Foster
1 Reputation
8 Guides authored
Cal Poly, Team 25-88, Amido Spring 2010 Member of Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,943
