LG VX4500 Display Screen Replacement
  1. LG VX4500 Display Screen Replacement, Battery: step 1, image 1 of 1
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 Display Screen Replacement: step 2, image 1 of 2 LG VX4500 Display Screen Replacement: step 2, image 2 of 2
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 Display Screen Replacement, Outer Display Cover: step 3, image 1 of 1
    • Remove 4 rubber grommets using the Spudger.
  4. LG VX4500 Display Screen Replacement: step 4, image 1 of 1
    • Remove 4 screws using the Phillips #00 Screwdriver.
  5. LG VX4500 Display Screen Replacement: step 5, image 1 of 3 LG VX4500 Display Screen Replacement: step 5, image 2 of 3 LG VX4500 Display Screen Replacement: step 5, image 3 of 3
    • Carefully pry off outer cover using iPod Opening Tool.
  6. LG VX4500 Display Screen Replacement, Display: step 6, image 1 of 2 LG VX4500 Display Screen Replacement, Display: step 6, image 2 of 2
    • Remove speaker using the Spudger.
  7. LG VX4500 Display Screen Replacement: step 7, image 1 of 2 LG VX4500 Display Screen Replacement: step 7, image 2 of 2
    • Remove vibrator using the Spudger.
  8. LG VX4500 Display Screen Replacement: step 8, image 1 of 2 LG VX4500 Display Screen Replacement: step 8, image 2 of 2
    • Lift up LCD display using iPod Opening Tool.
  9. LG VX4500 Display Screen Replacement: step 9, image 1 of 1
    • DO NOT TOUCH THE SOLDERING IRON. IT IS EXTREMELY HOT!
    • De-solder solder joint using Soldering Iron.
  10. LG VX4500 Display Screen Replacement: step 10, image 1 of 2 LG VX4500 Display Screen Replacement: step 10, image 2 of 2
    • Pry off ribbon cable using iPod Opening Tool.
David Foster
1 Reputation
8 Guides authored
Cal Poly, Team 25-88, Amido Spring 2010 Member of Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Members
19 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,416
