LG VX5200 Face Plate Replacement
  1. LG VX5200 Face Plate Replacement, Battery: step 1, image 1 of 2 LG VX5200 Face Plate Replacement, Battery: step 1, image 2 of 2
    • Turn the phone on its back.
  2. LG VX5200 Face Plate Replacement: step 2, image 1 of 2 LG VX5200 Face Plate Replacement: step 2, image 2 of 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Face Plate Replacement: step 3, image 1 of 2 LG VX5200 Face Plate Replacement: step 3, image 2 of 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Face Plate Replacement, Face Plate: step 4, image 1 of 3 LG VX5200 Face Plate Replacement, Face Plate: step 4, image 2 of 3 LG VX5200 Face Plate Replacement, Face Plate: step 4, image 3 of 3
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. LG VX5200 Face Plate Replacement: step 5, image 1 of 3 LG VX5200 Face Plate Replacement: step 5, image 2 of 3 LG VX5200 Face Plate Replacement: step 5, image 3 of 3
    • Insert the opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  6. LG VX5200 Face Plate Replacement: step 6, image 1 of 3 LG VX5200 Face Plate Replacement: step 6, image 2 of 3 LG VX5200 Face Plate Replacement: step 6, image 3 of 3
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
Douglas Blaalid
282 Reputation
8 Guides authored
Cal Poly, Team 4-13, Forte Winter 2010 Member of Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,039
