LG VX5200 Keypad Replacement
  1. LG VX5200 Keypad Replacement, Battery: step 1, image 1 of 2 LG VX5200 Keypad Replacement, Battery: step 1, image 2 of 2
    • Turn the phone on its back.
  2. LG VX5200 Keypad Replacement: step 2, image 1 of 2 LG VX5200 Keypad Replacement: step 2, image 2 of 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Keypad Replacement: step 3, image 1 of 2 LG VX5200 Keypad Replacement: step 3, image 2 of 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Keypad Replacement, LG VX5200 Rear Body Panel Disassembly: step 4, image 1 of 1
    • Orient the phone as shown with the battery already removed.
  5. LG VX5200 Keypad Replacement: step 5, image 1 of 3 LG VX5200 Keypad Replacement: step 5, image 2 of 3 LG VX5200 Keypad Replacement: step 5, image 3 of 3
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. LG VX5200 Keypad Replacement: step 6, image 1 of 3 LG VX5200 Keypad Replacement: step 6, image 2 of 3 LG VX5200 Keypad Replacement: step 6, image 3 of 3
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. LG VX5200 Keypad Replacement: step 7, image 1 of 1
    • Check to see that your device looks like the attached photo.
  8. LG VX5200 Keypad Replacement, main board: step 8, image 1 of 3 LG VX5200 Keypad Replacement, main board: step 8, image 2 of 3 LG VX5200 Keypad Replacement, main board: step 8, image 3 of 3
    • Locate the tabs that hold the logic board in place.
    • Pull the outer frame of the phone outwards to release the board from the tabs.
  9. LG VX5200 Keypad Replacement: step 9, image 1 of 3 LG VX5200 Keypad Replacement: step 9, image 2 of 3 LG VX5200 Keypad Replacement: step 9, image 3 of 3
    • Locate the copper connection (orange-colored) on the back of the board.
    • Pry the connector free from the board with your fingernail.
  10. LG VX5200 Keypad Replacement: step 10, image 1 of 1
    • Check to see that your device looks like the image shown.
    • Note: The image is shown with the LCD screen removed. This is not necessary for logic board removal.
  11. LG VX5200 Keypad Replacement, Keypad: step 11, image 1 of 3 LG VX5200 Keypad Replacement, Keypad: step 11, image 2 of 3 LG VX5200 Keypad Replacement, Keypad: step 11, image 3 of 3
    • Use your finger to lift up the keypad.
  12. LG VX5200 Keypad Replacement: step 12, image 1 of 1
    • Do not let the buttons fall out of the side casing of the phone!
    • Note: The image is shown with the LCD screen removed. This is not necessary for keypad repair.
Douglas Blaalid
282 Reputation
8 Guides authored
Cal Poly, Team 4-13, Forte Winter 2010 Member of Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,999
