LG VX5200 Screen Replacement
  1. LG VX5200 Screen Replacement, Screen: step 1, image 1 of 3 LG VX5200 Screen Replacement, Screen: step 1, image 2 of 3 LG VX5200 Screen Replacement, Screen: step 1, image 3 of 3
    • Pry the grey pieces of plastic off the corners of the screen with a spudger.
  2. LG VX5200 Screen Replacement: step 2, image 1 of 2 LG VX5200 Screen Replacement: step 2, image 2 of 2
    • Unscrew each of the four screws with a Phillips #00 Screwdriver.
    • These screws are the same size as the ones from the back casing, but are not the same size as the screw from the antenna.
  3. LG VX5200 Screen Replacement: step 3, image 1 of 2 LG VX5200 Screen Replacement: step 3, image 2 of 2
    • Close the phone after removing the screws.
    • Slide a spudger into the cracks in the top half of the phone's casing.
    • Wedge and lever the spudger to remove the casing.
    • Apply constant pressure to avoid cracking the plastic casing. This step can take a few minutes.
  4. LG VX5200 Screen Replacement: step 4, image 1 of 3 LG VX5200 Screen Replacement: step 4, image 2 of 3 LG VX5200 Screen Replacement: step 4, image 3 of 3
    • Remove the chipboard from the screen by sliding a plastic spudger under the screen and lifting.
    • Use a plastic spudger to avoid short-circuiting the phone's electronics.
    • Gently lift the speaker out of the plastic casing using a plastic spudger.
    • Remove the small battery adjacent to the speaker with a plastic spudger.
  5. LG VX5200 Screen Replacement: step 5, image 1 of 3 LG VX5200 Screen Replacement: step 5, image 2 of 3 LG VX5200 Screen Replacement: step 5, image 3 of 3
    • Slide and lever a plastic spudger between the screen and it's housing.
    • Avoid tearing the wires connecting the screen, the small battery and the speaker.
    • Remove the chip connecting the screen to the camera using your fingers.
jmarcum
16 Reputation
1 Guide authored
Cal Poly, Team 9-18, Regan Fall 2009 Member of Cal Poly, Team 9-18, Regan Fall 2009
CPSU-REGAN-F09S9G18
5 Members
2 Guides authored
1 Guide Comment
The “battery” beside the speaker isn’t the battery, it’s the phone vibrator. Still a good guide, however
Kaleb White - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 3,580
