LG VX5400 Keypad Replacement
  1. LG VX5400 Keypad Replacement, Battery: step 1, image 1 of 1
    • Turn off the cell phone and turn it over on its back side
  2. LG VX5400 Keypad Replacement: step 2, image 1 of 1
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  3. LG VX5400 Keypad Replacement: step 3, image 1 of 3 LG VX5400 Keypad Replacement: step 3, image 2 of 3 LG VX5400 Keypad Replacement: step 3, image 3 of 3
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
  4. LG VX5400 Keypad Replacement, Keypad: step 4, image 1 of 1
    • Remove the rubber stopper from the back top of the phone with the pointed end of a spudger.
  5. LG VX5400 Keypad Replacement: step 5, image 1 of 1
    • Use the Phillip screw driver to remove the hidden screw, which is marked by the red square
  6. LG VX5400 Keypad Replacement: step 6, image 1 of 1
    • Gently split open the front and back of the bottom casing of the phone with fingers.
  7. LG VX5400 Keypad Replacement: step 7, image 1 of 1
    • Carefully pull the key pad from the phone through the opening.
  8. LG VX5400 Keypad Replacement: step 8, image 1 of 1
    • See here for parts that have been removed.
Vanessa Panchal
1 Reputation
1 Guide authored
Cal Poly, Team 26-26, Regan Spring 2010 Member of Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,421
