LG VX6000 Logic Board Replacement
  1. LG VX6000 Logic Board Replacement, Battery: step 1, image 1 of 1
    • Locate the dark gray tab on the back of the phone.
    • Push the tab towards the top of the phone to release the battery.
  2. LG VX6000 Logic Board Replacement: step 2, image 1 of 1
    • Lift and rotate the battery away from the bottom edge.
    • Remove the battery.
  3. LG VX6000 Logic Board Replacement, Body: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Carefully use tweezers to remove the two rubber cushions located at the top of the phone.
    • Only remove the two cushions that are circled!
  4. LG VX6000 Logic Board Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the six screws highlighted on the back of the phone.
    • Place the screws on an uncluttered surface or in a small container.
  5. LG VX6000 Logic Board Replacement: step 5, image 1 of 1
    • Carefully remove the back of the phone with your fingernails or tweezers.
    • There are red and blue wires connected to the motherboard. Forcing the components apart could damage the wires.
    • The red and blue wires must be plugged in to reassemble.
  6. LG VX6000 Logic Board Replacement, Logic Board: step 6, image 1 of 1
    • Carefully peel away the adhesive tab.
    • The tab should not be completely separated from the phone.
  7. LG VX6000 Logic Board Replacement: step 7, image 1 of 2 LG VX6000 Logic Board Replacement: step 7, image 2 of 2
    • Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
    • Carefully pry the connector away from the motherboard to remove it from the phone.
    • Do not pull forcefully
  8. LG VX6000 Logic Board Replacement: step 8, image 1 of 1
    • Gently lift the corner of the motherboard away from the casing.
Adam Altman
1 Reputation
3 Guides authored
Cal Poly, Team 4-11, Forte Winter 2010 Member of Cal Poly, Team 4-11, Forte Winter 2010
CPSU-FORTE-W10S4G11
5 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 18
All Time: 3,270
