LG VX6100 Keypad Replacement
  1. LG VX6100 Keypad Replacement, Back Cover: step 1, image 1 of 1
    • Push down on the gray "PUSH" button on the back side of the phone.
    • Slide the back case downward. Then, lift and remove the case.
  2. LG VX6100 Keypad Replacement: step 2, image 1 of 1
    • Lift up on the battery to remove it from the case.
  3. LG VX6100 Keypad Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use a push-pin or tweezers to pry both of the tear-shaped screw covers out of the top of the phone.
  4. LG VX6100 Keypad Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew the six case screws from the back of the phone.
  5. LG VX6100 Keypad Replacement: step 5, image 1 of 2 LG VX6100 Keypad Replacement: step 5, image 2 of 2
    • Insert a plastic opener tool through the seam between the back case and the rest of the phone.
    • Slowly slide the tool along the seam. Lift up on the back case while you do this until the back case comes apart.
  6. LG VX6100 Keypad Replacement, Keypad: step 6, image 1 of 1
    • Lift the bottom of the logic board out of the case.
    • Make sure not to lift the top of the logic board, since it is still connected to the backcase of the phone.
  7. LG VX6100 Keypad Replacement: step 7, image 1 of 1
    • Gently lift up on any edge of the white keypad to remove it from the phone case.
Teal
1 Reputation
2 Guides authored
Cal Poly, Team 12-39, Regan Spring 2012 Member of Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Members
16 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 7
All Time: 573
