LG VX7000 Internal LCD Screen Replacement
Nichole Shaw
Nichole Shaw and 2 other contributors
Last updated on May 7, 2024
15 - 30 minutes
Moderate
Missing Prerequisites
Introduction
Go to step 1
Replace a cracked internal LCD display.
Note: to replace the internal display, you must replace the entire face plate, not just the plastic screen.
Tools
  1. LG VX7000 Internal LCD Screen Replacement, Internal LCD Screen: step 1, image 1 of 1
    Tool used on this step:
    • Using Tweezers, remove 4 rubber screw covers.
    • Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
    • NOTE: Screws will not come completely out of phone.
  2. LG VX7000 Internal LCD Screen Replacement: step 2, image 1 of 1
    • Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • NOTE: There will be a significant amount of resistance to removing the face plate from the phone.
  3. LG VX7000 Internal LCD Screen Replacement: step 3, image 1 of 1
    • Unsnap gold plate from the secondary logic board.
    • Reposition the plate so that it is out of the way for face plate removal.
  4. LG VX7000 Internal LCD Screen Replacement: step 4, image 1 of 1
    • Twist upper half of face plate in order to release it from the hinge.
    • Using tweezers detach the speaker and the secondary battery from the faceplate, leaving wires attached.
  5. LG VX7000 Internal LCD Screen Replacement: step 5, image 1 of 1
    • Align new face plate in correct orientation in order to install.
Nichole Shaw
1 Reputation
7 Guides authored
Cal Poly, Team 18-75, Johann Spring 2010 Member of Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,248
