LG VX8700 Keypad Replacement
  1. LG VX8700 Keypad Replacement, Battery: step 1, image 1 of 2 LG VX8700 Keypad Replacement, Battery: step 1, image 2 of 2
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
  2. LG VX8700 Keypad Replacement: step 2, image 1 of 2 LG VX8700 Keypad Replacement: step 2, image 2 of 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
  3. LG VX8700 Keypad Replacement, Keypad: step 3, image 1 of 2 LG VX8700 Keypad Replacement, Keypad: step 3, image 2 of 2
    • Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
  4. LG VX8700 Keypad Replacement: step 4, image 1 of 2 LG VX8700 Keypad Replacement: step 4, image 2 of 2
    • Insert the tip of the iFixit opening tool into the small notch on the side of the case.
    • Slide the opening tool along the seam and around the edge of the phone to separate the case.
  5. LG VX8700 Keypad Replacement: step 5, image 1 of 1
    • Separate the two halves of the phone.
    • The back of the phone, which houses the motherboard and keypad, is displayed on the left.
    • The plastic casing is displayed on the right.
  6. LG VX8700 Keypad Replacement: step 6, image 1 of 3 LG VX8700 Keypad Replacement: step 6, image 2 of 3 LG VX8700 Keypad Replacement: step 6, image 3 of 3
    • Hold the phone casing with one hand and the keypad assembly with the other.
    • Separate the phone casing from the keypad/motherboard.
  7. LG VX8700 Keypad Replacement: step 7, image 1 of 2 LG VX8700 Keypad Replacement: step 7, image 2 of 2
    • Pull the two boards apart to separate the keypad from the motherboard.
tnscholz
18 Reputation
1 Guide authored
Cal Poly, Team 8-16, Maness Winter 2012 Member of Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Members
14 Guides authored
1 Guide Comment
When I separated the two halves a small brass piece came out and your instructions do not show nor mention what this is or where it goes. Not even a caution about it coming out upon separation of the halves. It appears to belong on one of the screw posts and because it is brass I believe it is supposed to complete a circuit.
gfon - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 866
