LG Volt Power Button Replacement
  1. LG Volt Power Button Replacement, Power Button: step 1, image 1 of 3 LG Volt Power Button Replacement, Power Button: step 1, image 2 of 3 LG Volt Power Button Replacement, Power Button: step 1, image 3 of 3
    • Pry back cover with finger in the crease.
    • Remove back casing.
  2. LG Volt Power Button Replacement: step 2, image 1 of 3 LG Volt Power Button Replacement: step 2, image 2 of 3 LG Volt Power Button Replacement: step 2, image 3 of 3
    • With your finger, pry the battery out through the crease made for removal.
  3. LG Volt Power Button Replacement: step 3, image 1 of 3 LG Volt Power Button Replacement: step 3, image 2 of 3 LG Volt Power Button Replacement: step 3, image 3 of 3
    • Remove all 11 (4mm) screws with the JIS #000 screwdriver
    • There are three screws on top, three above the battery, one next to the battery, one under the battery and three at the bottom of the phone.
  4. LG Volt Power Button Replacement: step 4, image 1 of 3 LG Volt Power Button Replacement: step 4, image 2 of 3 LG Volt Power Button Replacement: step 4, image 3 of 3
    • Use the plastic opening tool to remove the back housing from the frame of the phone.
  5. LG Volt Power Button Replacement: step 5, image 1 of 3 LG Volt Power Button Replacement: step 5, image 2 of 3 LG Volt Power Button Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Use the precision tweezers set to gently lift the rubber tab off its anchor.
    • Then push the power button through the cutout to remove completely.
Adrian Soldan
464 Reputation
4 Guides authored
USF Tampa, Team S3-G3, Cannon Fall 2017 Member of USF Tampa, Team S3-G3, Cannon Fall 2017
USFT-CANNON-F17S3G3
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 398
