LG Voyager Micro SD Replacement
  1. LG Voyager Micro SD Replacement, Micro SD: step 1, image 1 of 1
    • Turn the phone onto its side so the label micro SD is facing upside down.
    • Once on its side, lift the micro SD cover up and swivel it away from the opening.
  2. LG Voyager Micro SD Replacement: step 2, image 1 of 2 LG Voyager Micro SD Replacement: step 2, image 2 of 2
    • The Micro SD card will appear as a thin plastic piece sticking out of the phone
    • Gently push down on the card, you should hear a click, and then it will "spring" back at you.
    • The card should be sticking out of the phone slightly once this is done.
    • Remove the card from the slot
Michelle
20 Reputation
2 Guides authored
Cal Poly, Team 17-26, Amido Spring 2012 Member of Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 7
All Time: 473
