LG WM3050CW Detergent Bellows Replacement
  1. LG WM3050CW Detergent Bellows Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Detergent Bellows Replacement, Safety Precautions: step 1, image 2 of 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Detergent Bellows Replacement, Unfasten the top panel: step 2, image 1 of 3 LG WM3050CW Detergent Bellows Replacement, Unfasten the top panel: step 2, image 2 of 3 LG WM3050CW Detergent Bellows Replacement, Unfasten the top panel: step 2, image 3 of 3
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Detergent Bellows Replacement, Remove the top panel: step 3, image 1 of 2 LG WM3050CW Detergent Bellows Replacement, Remove the top panel: step 3, image 2 of 2
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Detergent Bellows Replacement: step 4, image 1 of 2 LG WM3050CW Detergent Bellows Replacement: step 4, image 2 of 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Detergent Bellows Replacement, Disconnect the control panel: step 5, image 1 of 3 LG WM3050CW Detergent Bellows Replacement, Disconnect the control panel: step 5, image 2 of 3 LG WM3050CW Detergent Bellows Replacement, Disconnect the control panel: step 5, image 3 of 3
    • Disconnect the three harness connectors for the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  6. LG WM3050CW Detergent Bellows Replacement, Unclip the control panel cable: step 6, image 1 of 2 LG WM3050CW Detergent Bellows Replacement, Unclip the control panel cable: step 6, image 2 of 2
    • Use your hands to unclip the control panel cable from the detergent dispenser.
  7. LG WM3050CW Detergent Bellows Replacement, Unclip the control panel cable: step 7, image 1 of 3 LG WM3050CW Detergent Bellows Replacement, Unclip the control panel cable: step 7, image 2 of 3 LG WM3050CW Detergent Bellows Replacement, Unclip the control panel cable: step 7, image 3 of 3
    • Insert a flathead screwdriver between the chassis and the plastic clip securing the control panel cable.
    • Compress the clip and slide it out of the chassis to remove it.
    • Move the cables out of the way of the detergent dispenser hoses before you continue.
  8. LG WM3050CW Detergent Bellows Replacement, Detergent dispenser hose information: step 8, image 1 of 1
    • To prevent confusion, label each hose and its corresponding dispenser connection.
    • You can use masking tape or mark the components themselves.
  9. LG WM3050CW Detergent Bellows Replacement: step 9, image 1 of 2 LG WM3050CW Detergent Bellows Replacement: step 9, image 2 of 2
    • Use slip joint pliers to pinch the detergent dispenser hose clamp and pull it away from the assembly.
  10. LG WM3050CW Detergent Bellows Replacement: step 10, image 1 of 2 LG WM3050CW Detergent Bellows Replacement: step 10, image 2 of 2
    • Use slip joint pliers to gently rotate the detergent dispenser hose back and forth around its connection and loosen it.
  11. LG WM3050CW Detergent Bellows Replacement: step 11, image 1 of 2 LG WM3050CW Detergent Bellows Replacement: step 11, image 2 of 2
    • Pull the detergent dispenser hose straight off its connection on the assembly.
    • Repeat the loosening and removal procedure for each hose.
  12. LG WM3050CW Detergent Bellows Replacement, Disconnect the dispenser: step 12, image 1 of 3 LG WM3050CW Detergent Bellows Replacement, Disconnect the dispenser: step 12, image 2 of 3 LG WM3050CW Detergent Bellows Replacement, Disconnect the dispenser: step 12, image 3 of 3
    • Use a Phillips driver to loosen the screw securing the bellows to the detergent dispenser.
    • Pull the bellows straight off its connection on the dispenser to disconnect it.
  13. LG WM3050CW Detergent Bellows Replacement, Disconnect the bellows: step 13, image 1 of 3 LG WM3050CW Detergent Bellows Replacement, Disconnect the bellows: step 13, image 2 of 3 LG WM3050CW Detergent Bellows Replacement, Disconnect the bellows: step 13, image 3 of 3
    • Use a Phillips driver to loosen the screw securing the bellows to the drum.
    • Pull the bellows straight up from the drum to disconnect it.
  14. LG WM3050CW Detergent Bellows Replacement, Remove the bellows: step 14, image 1 of 1
    • Remove the bellows.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30,695 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 116
