LG WM3050CW Detergent Dispenser Replacement
  1. LG WM3050CW Detergent Dispenser Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Detergent Dispenser Replacement, Safety Precautions: step 1, image 2 of 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Detergent Dispenser Replacement, Unfasten the top panel: step 2, image 1 of 3 LG WM3050CW Detergent Dispenser Replacement, Unfasten the top panel: step 2, image 2 of 3 LG WM3050CW Detergent Dispenser Replacement, Unfasten the top panel: step 2, image 3 of 3
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Detergent Dispenser Replacement, Remove the top panel: step 3, image 1 of 2 LG WM3050CW Detergent Dispenser Replacement, Remove the top panel: step 3, image 2 of 2
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Detergent Dispenser Replacement: step 4, image 1 of 2 LG WM3050CW Detergent Dispenser Replacement: step 4, image 2 of 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Detergent Dispenser Replacement, Remove the detergent drawer: step 5, image 1 of 2 LG WM3050CW Detergent Dispenser Replacement, Remove the detergent drawer: step 5, image 2 of 2
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG WM3050CW Detergent Dispenser Replacement: step 6, image 1 of 3 LG WM3050CW Detergent Dispenser Replacement: step 6, image 2 of 3 LG WM3050CW Detergent Dispenser Replacement: step 6, image 3 of 3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG WM3050CW Detergent Dispenser Replacement, Disconnect the control panel: step 7, image 1 of 3 LG WM3050CW Detergent Dispenser Replacement, Disconnect the control panel: step 7, image 2 of 3 LG WM3050CW Detergent Dispenser Replacement, Disconnect the control panel: step 7, image 3 of 3
    • Disconnect the three harness connectors for the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG WM3050CW Detergent Dispenser Replacement, Unclip the control panel cable: step 8, image 1 of 2 LG WM3050CW Detergent Dispenser Replacement, Unclip the control panel cable: step 8, image 2 of 2
    • Use your hands to unclip the control panel cable from the detergent dispenser.
  9. LG WM3050CW Detergent Dispenser Replacement, Unclip the control panel cable: step 9, image 1 of 3 LG WM3050CW Detergent Dispenser Replacement, Unclip the control panel cable: step 9, image 2 of 3 LG WM3050CW Detergent Dispenser Replacement, Unclip the control panel cable: step 9, image 3 of 3
    • Insert a flathead screwdriver between the chassis and the plastic clip securing the control panel cable.
    • Compress the clip and slide it out of the chassis to remove it.
    • Move the cables out of the way of the detergent dispenser hoses before you continue.
  10. LG WM3050CW Detergent Dispenser Replacement, Detergent dispenser hose information: step 10, image 1 of 1
    • To prevent confusion, label each hose and its corresponding dispenser connection.
    • You can use masking tape or mark the components themselves.
  11. LG WM3050CW Detergent Dispenser Replacement: step 11, image 1 of 2 LG WM3050CW Detergent Dispenser Replacement: step 11, image 2 of 2
    • Use slip joint pliers to pinch the detergent dispenser hose clamp and pull it away from the assembly.
  12. LG WM3050CW Detergent Dispenser Replacement: step 12, image 1 of 2 LG WM3050CW Detergent Dispenser Replacement: step 12, image 2 of 2
    • Use slip joint pliers to gently rotate the detergent dispenser hose back and forth around its connection and loosen it.
  13. LG WM3050CW Detergent Dispenser Replacement: step 13, image 1 of 2 LG WM3050CW Detergent Dispenser Replacement: step 13, image 2 of 2
    • Pull the detergent dispenser hose straight off its connection on the assembly.
    • Repeat the loosening and removal procedure for each hose.
  14. LG WM3050CW Detergent Dispenser Replacement, Disconnect the dispenser: step 14, image 1 of 3 LG WM3050CW Detergent Dispenser Replacement, Disconnect the dispenser: step 14, image 2 of 3 LG WM3050CW Detergent Dispenser Replacement, Disconnect the dispenser: step 14, image 3 of 3
    • Use a Phillips driver to loosen the screw securing the bellows to the detergent dispenser.
    • Pull the bellows straight off its connection on the dispenser to disconnect it.
  15. LG WM3050CW Detergent Dispenser Replacement, Unfasten the detergent dispenser: step 15, image 1 of 1
    • Use a Phillips driver to remove the two 26.3 mm‑long screws securing the detergent dispenser.
  16. LG WM3050CW Detergent Dispenser Replacement, Unclip the detergent dispenser: step 16, image 1 of 3 LG WM3050CW Detergent Dispenser Replacement, Unclip the detergent dispenser: step 16, image 2 of 3 LG WM3050CW Detergent Dispenser Replacement, Unclip the detergent dispenser: step 16, image 3 of 3
    • Slide the detergent dispenser toward the back of the device to unclip it from the chassis.
    • Pull the dispenser toward the left edge of the device to completely separate it from the chassis.
  17. LG WM3050CW Detergent Dispenser Replacement, Remove the detergent dispenser: step 17, image 1 of 1
    • Remove the detergent dispenser.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30,797 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,086 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 157
