LG WM3050CW Drain Filter Replacement
  1. LG WM3050CW Drain Filter Replacement, Unclip the filter door: step 1, image 1 of 2 LG WM3050CW Drain Filter Replacement, Unclip the filter door: step 1, image 2 of 2
    • Unclip the filter door from its slot in the chassis and let it rest on the ground.
  2. LG WM3050CW Drain Filter Replacement, Drain the drain filter hose: step 2, image 1 of 3 LG WM3050CW Drain Filter Replacement, Drain the drain filter hose: step 2, image 2 of 3 LG WM3050CW Drain Filter Replacement, Drain the drain filter hose: step 2, image 3 of 3
    • Place a bowl next to the device.
    • Pull the drain filterhose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  3. LG WM3050CW Drain Filter Replacement, Remove the drain filter: step 3, image 1 of 3 LG WM3050CW Drain Filter Replacement, Remove the drain filter: step 3, image 2 of 3 LG WM3050CW Drain Filter Replacement, Remove the drain filter: step 3, image 3 of 3
    • Twist the drain filter counterclockwise until its fully disconnected from the chassis.
    • Remove the drain filter.
Repair didn’t go as planned? Ask our Answers community for help.
Alex Diaz-Kokaisl
127,722 Reputation
592 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 21
All Time: 202
