LG WM3050CW Electrical Noise Filter Replacement
  1. LG WM3050CW Electrical Noise Filter Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Electrical Noise Filter Replacement, Safety Precautions: step 1, image 2 of 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Electrical Noise Filter Replacement, Unfasten the top panel: step 2, image 1 of 3 LG WM3050CW Electrical Noise Filter Replacement, Unfasten the top panel: step 2, image 2 of 3 LG WM3050CW Electrical Noise Filter Replacement, Unfasten the top panel: step 2, image 3 of 3
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Electrical Noise Filter Replacement, Remove the top panel: step 3, image 1 of 2 LG WM3050CW Electrical Noise Filter Replacement, Remove the top panel: step 3, image 2 of 2
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Electrical Noise Filter Replacement: step 4, image 1 of 2 LG WM3050CW Electrical Noise Filter Replacement: step 4, image 2 of 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Electrical Noise Filter Replacement, Disconnect the noise filter: step 5, image 1 of 3 LG WM3050CW Electrical Noise Filter Replacement, Disconnect the noise filter: step 5, image 2 of 3 LG WM3050CW Electrical Noise Filter Replacement, Disconnect the noise filter: step 5, image 3 of 3
    • Disconnect the two spade connectors attached to the noise filter.
    • Always grip cables by their connectors and not the wires themselves.
  6. LG WM3050CW Electrical Noise Filter Replacement, Unfasten the noise filter: step 6, image 1 of 1
    • Use a Phillips driver to remove the 12.5 mm-long screw securing the noise filter.
  7. LG WM3050CW Electrical Noise Filter Replacement, Remove the noise filter: step 7, image 1 of 3 LG WM3050CW Electrical Noise Filter Replacement, Remove the noise filter: step 7, image 2 of 3 LG WM3050CW Electrical Noise Filter Replacement, Remove the noise filter: step 7, image 3 of 3
    • Slide the noise filter towards the front of the device to unclip it from the chassis.
    • Pull the filter downward to completely separate it from the device.
    • Remove the filter.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30,695 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 89
