LG WM3050CW Inlet Valve Assembly Replacement
  1. LG WM3050CW Inlet Valve Assembly Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Inlet Valve Assembly Replacement, Safety Precautions: step 1, image 2 of 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Inlet Valve Assembly Replacement, Unfasten the top panel: step 2, image 1 of 3 LG WM3050CW Inlet Valve Assembly Replacement, Unfasten the top panel: step 2, image 2 of 3 LG WM3050CW Inlet Valve Assembly Replacement, Unfasten the top panel: step 2, image 3 of 3
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Inlet Valve Assembly Replacement, Remove the top panel: step 3, image 1 of 2 LG WM3050CW Inlet Valve Assembly Replacement, Remove the top panel: step 3, image 2 of 2
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Inlet Valve Assembly Replacement: step 4, image 1 of 2 LG WM3050CW Inlet Valve Assembly Replacement: step 4, image 2 of 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Inlet Valve Assembly Replacement, Inlet valve information: step 5, image 1 of 3 LG WM3050CW Inlet Valve Assembly Replacement, Inlet valve information: step 5, image 2 of 3 LG WM3050CW Inlet Valve Assembly Replacement, Inlet valve information: step 5, image 3 of 3
    • To prevent confusion, label each valve and its corresponding hose.
    • You can use masking tape or mark the components themselves.
    • Repeat the labelling procedure for each valve and its corresponding connector.
  6. LG WM3050CW Inlet Valve Assembly Replacement, Disconnect the inlet valve: step 6, image 1 of 3 LG WM3050CW Inlet Valve Assembly Replacement, Disconnect the inlet valve: step 6, image 2 of 3 LG WM3050CW Inlet Valve Assembly Replacement, Disconnect the inlet valve: step 6, image 3 of 3
    • Disconnect the three spade connectors from the inlet valve.
    • Always grip cables by their connectors and not the wires themselves.
  7. LG WM3050CW Inlet Valve Assembly Replacement: step 7, image 1 of 1
    • Place a dry rag under the inlet valve to soak up any lingering water.
  8. LG WM3050CW Inlet Valve Assembly Replacement: step 8, image 1 of 3 LG WM3050CW Inlet Valve Assembly Replacement: step 8, image 2 of 3 LG WM3050CW Inlet Valve Assembly Replacement: step 8, image 3 of 3
    • Use slip joint pliers to pinch the inlet valve hose clamp and pull it away from the inlet valve assembly.
  9. LG WM3050CW Inlet Valve Assembly Replacement: step 9, image 1 of 2 LG WM3050CW Inlet Valve Assembly Replacement: step 9, image 2 of 2
    • Use slip joint pliers to rotate the inlet valve hose back and forth around its connection and loosen it.
  10. LG WM3050CW Inlet Valve Assembly Replacement: step 10, image 1 of 2 LG WM3050CW Inlet Valve Assembly Replacement: step 10, image 2 of 2
    • Pull the inlet valve hose straight off its connection on the inlet valve assembly.
  11. LG WM3050CW Inlet Valve Assembly Replacement: step 11, image 1 of 1
    • Repeat the previous three steps for each remaining hose attached to the inlet valve assembly.
  12. LG WM3050CW Inlet Valve Assembly Replacement, Remove the filters: step 12, image 1 of 3 LG WM3050CW Inlet Valve Assembly Replacement, Remove the filters: step 12, image 2 of 3 LG WM3050CW Inlet Valve Assembly Replacement, Remove the filters: step 12, image 3 of 3
    • If your replacement part comes with filters pre-installed, skip this step.
    • Use needle nose pliers to pull the inlet valve filters straight out of the inlets in the chassis.
    • Remove the filters.
  13. LG WM3050CW Inlet Valve Assembly Replacement, Unfasten the inlet valve assembly: step 13, image 1 of 1
    • Use a Phillips driver to remove the two 14.4 mm‑long screws securing the inlet valve assembly.
  14. LG WM3050CW Inlet Valve Assembly Replacement, Remove the inlet valve assembly: step 14, image 1 of 3 LG WM3050CW Inlet Valve Assembly Replacement, Remove the inlet valve assembly: step 14, image 2 of 3 LG WM3050CW Inlet Valve Assembly Replacement, Remove the inlet valve assembly: step 14, image 3 of 3
    • Pull the inlet valve assembly straight out of its slot in the chassis to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30,695 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 209
