LG WM3050CW Pressure Sensor Replacement
  1. LG WM3050CW Pressure Sensor Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Pressure Sensor Replacement, Safety Precautions: step 1, image 2 of 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Pressure Sensor Replacement, Unfasten the top panel: step 2, image 1 of 3 LG WM3050CW Pressure Sensor Replacement, Unfasten the top panel: step 2, image 2 of 3 LG WM3050CW Pressure Sensor Replacement, Unfasten the top panel: step 2, image 3 of 3
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Pressure Sensor Replacement, Remove the top panel: step 3, image 1 of 2 LG WM3050CW Pressure Sensor Replacement, Remove the top panel: step 3, image 2 of 2
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Pressure Sensor Replacement: step 4, image 1 of 2 LG WM3050CW Pressure Sensor Replacement: step 4, image 2 of 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Pressure Sensor Replacement, Disconnect the pressure sensor: step 5, image 1 of 2 LG WM3050CW Pressure Sensor Replacement, Disconnect the pressure sensor: step 5, image 2 of 2
    • Disconnect the spade connector from the pressure sensor.
    • Always grip cables by their connectors and not the wires themselves.
  6. LG WM3050CW Pressure Sensor Replacement: step 6, image 1 of 2 LG WM3050CW Pressure Sensor Replacement: step 6, image 2 of 2
    • Disconnect the hose from the pressure sensor.
  7. LG WM3050CW Pressure Sensor Replacement, Unfasten the pressure sensor: step 7, image 1 of 1
    • Use a Phillips driver to remove the 16.5 mm-long screw securing the pressure sensor.
  8. LG WM3050CW Pressure Sensor Replacement, Remove the pressure sensor: step 8, image 1 of 3 LG WM3050CW Pressure Sensor Replacement, Remove the pressure sensor: step 8, image 2 of 3 LG WM3050CW Pressure Sensor Replacement, Remove the pressure sensor: step 8, image 3 of 3
    • Rotate the pressure sensor toward the left edge of the washing machine to unclip it from the main board cover.
  9. LG WM3050CW Pressure Sensor Replacement: step 9, image 1 of 2 LG WM3050CW Pressure Sensor Replacement: step 9, image 2 of 2
    • Lift the pressure sensor away from its slot on the main board cover to remove it.
    • During reassembly, align the pressure sensor with the hole next to its slot before rotating it back into its original position.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30,797 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,086 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 111
