LG WM3050CW Rotor Replacement
  1. LG WM3050CW Rotor Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Rotor Replacement, Safety Precautions: step 1, image 2 of 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Rotor Replacement, Unfasten the rear panel: step 2, image 1 of 3 LG WM3050CW Rotor Replacement, Unfasten the rear panel: step 2, image 2 of 3 LG WM3050CW Rotor Replacement, Unfasten the rear panel: step 2, image 3 of 3
    • Use a Phillips driver to remove the four 10.7 mm‑long screws securing the rear panel.
  3. LG WM3050CW Rotor Replacement, Remove the rear panel: step 3, image 1 of 3 LG WM3050CW Rotor Replacement, Remove the rear panel: step 3, image 2 of 3 LG WM3050CW Rotor Replacement, Remove the rear panel: step 3, image 3 of 3
    • Lift the rear panel upward to release its bottom clips.
    • Pull the rear panel away from the chassis to release the remaining clips.
  4. LG WM3050CW Rotor Replacement: step 4, image 1 of 1
    • Remove the rear panel.
  5. LG WM3050CW Rotor Replacement, Unfasten the rotor: step 5, image 1 of 2 LG WM3050CW Rotor Replacement, Unfasten the rotor: step 5, image 2 of 2
    • Use an impact driver to remove the 17 mm nut securing the rotor.
    • Alternatively, you can use a wrench and a hammer to loosen the nut.
    • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
  6. LG WM3050CW Rotor Replacement, Remove the rotor: step 6, image 1 of 2 LG WM3050CW Rotor Replacement, Remove the rotor: step 6, image 2 of 2
    • The rotor is magnetically attracted to the stator.
    • Pull the rotor straight off the stator and drive shaft splines to remove it.
    • Wiggle the rotor as you pull to help disconnect it.
    • This may require significant force.
    • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30,797 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,058 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 219
