LG Watch Urbane Motherboard Replacement
  1. LG Watch Urbane Motherboard Replacement, Battery: step 1, image 1 of 2 LG Watch Urbane Motherboard Replacement, Battery: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Motherboard Replacement: step 2, image 1 of 2 LG Watch Urbane Motherboard Replacement: step 2, image 2 of 2
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Motherboard Replacement: step 3, image 1 of 3 LG Watch Urbane Motherboard Replacement: step 3, image 2 of 3 LG Watch Urbane Motherboard Replacement: step 3, image 3 of 3
    Magnetic Project Mat
    $19.95
    Buy
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Motherboard Replacement: step 4, image 1 of 3 LG Watch Urbane Motherboard Replacement: step 4, image 2 of 3 LG Watch Urbane Motherboard Replacement: step 4, image 3 of 3
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
  5. LG Watch Urbane Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • And now you have your motherboard
3 other people completed this guide.
Rey Diaz
699 Reputation
2 Guides authored
USF Tampa, Team 1-4, Remmell Fall 2015 Member of USF Tampa, Team 1-4, Remmell Fall 2015
USFT-REMMELL-F15S1G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,171
