LG X Power Battery Replacement
  1. LG X Power Battery Replacement, LG X Power Disassembly: step 1, image 1 of 2 LG X Power Battery Replacement, LG X Power Disassembly: step 1, image 2 of 2
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Battery Replacement: step 2, image 1 of 2 LG X Power Battery Replacement: step 2, image 2 of 2
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Battery Replacement: step 3, image 1 of 2 LG X Power Battery Replacement: step 3, image 2 of 2
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Battery Replacement, Battery: step 4, image 1 of 3 LG X Power Battery Replacement, Battery: step 4, image 2 of 3 LG X Power Battery Replacement, Battery: step 4, image 3 of 3
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  5. LG X Power Battery Replacement: step 5, image 1 of 1
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  6. LG X Power Battery Replacement: step 6, image 1 of 1
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  7. LG X Power Battery Replacement: step 7, image 1 of 2 LG X Power Battery Replacement: step 7, image 2 of 2
    • Use a spudger and plastic opening tool to carefully pry up the battery.
    • There is a strong adhesive on the back of the battery that will make it difficult to remove.
7 other people completed this guide.
Chad Sears
1,200 Reputation
5 Guides authored
USF Tampa, Team S3-G6, Nance Spring 2018 Member of USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Members
12 Guides authored
5 Guide Comments
lg x power mobail sarkit board+ bettery kaha pe milegi
HASIBUL RAHAMAN - Reply
Were can i buy the battery?
Tasha Boost - Reply
thx for rundown
George Pryor - Reply
On my H700 Venture....only have to remove 3 screws on the charger port end of the phone to directly access the battery connection. No messing with cameras or motherboard moving. Be aware once you open phone it will no longer be waterproof. Battery from Amazon.
May not be worth the effort. Replace battery (twice) and all I get is a gray battery icon on the screen with a red flashing question mark when I hook up original equipment LG charger....for hours.
Bought a renewed H700 on Amazon, works great. My bad...I had not backed up my contact list from the phone internal storage...learned the hard way "internal" storage is not the SIM card. Anyone know how to recover contact list from a dead phone ? Contact me at heyinway@yahoo.com Thanks !
Ronald Fulton - Reply
Hey, great guide, thank you for going through the effort to document what it looks like.
It would have helped me to know where to insert the tool when removing the mid-frame -- I didn't know where to insert the tool or what the mid-frame will look like once it's on its way off the rest of the phone.
Best regards,
Yena
maktecfam - Reply
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 36
All Time: 20,609
