LG X Power Camera Replacement
  1. LG X Power Camera Replacement, LG X Power Disassembly: step 1, image 1 of 2 LG X Power Camera Replacement, LG X Power Disassembly: step 1, image 2 of 2
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Camera Replacement: step 2, image 1 of 2 LG X Power Camera Replacement: step 2, image 2 of 2
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Camera Replacement: step 3, image 1 of 2 LG X Power Camera Replacement: step 3, image 2 of 2
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Camera Replacement, Main Camera: step 4, image 1 of 2 LG X Power Camera Replacement, Main Camera: step 4, image 2 of 2
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
Chad Sears
1,200 Reputation
5 Guides authored
USF Tampa, Team S3-G6, Nance Spring 2018 Member of USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 732
