LG X Power Charging Port Replacement
  1. LG X Power Charging Port Replacement, LG X Power Disassembly: step 1, image 1 of 2 LG X Power Charging Port Replacement, LG X Power Disassembly: step 1, image 2 of 2
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Charging Port Replacement: step 2, image 1 of 2 LG X Power Charging Port Replacement: step 2, image 2 of 2
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Charging Port Replacement: step 3, image 1 of 2 LG X Power Charging Port Replacement: step 3, image 2 of 2
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Charging Port Replacement, Charging Port: step 4, image 1 of 3 LG X Power Charging Port Replacement, Charging Port: step 4, image 2 of 3 LG X Power Charging Port Replacement, Charging Port: step 4, image 3 of 3
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  5. LG X Power Charging Port Replacement: step 5, image 1 of 1
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  6. LG X Power Charging Port Replacement: step 6, image 1 of 1
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  7. LG X Power Charging Port Replacement: step 7, image 1 of 1
    • Desolder the MicroUSB charging port from the motherboard.
    • If you need help soldering, follow this guide.
5 other people completed this guide.
Chad Sears
1,191 Reputation
5 Guides authored
USF Tampa, Team S3-G6, Nance Spring 2018 Member of USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Members
12 Guides authored
One Comment
Where can i get the charging port part? There are so many different usb female ports.
Wayne Newell - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 6,058
