LG X Style Rear Facing Camera Replacement
  1. LG X Style Rear Facing Camera  Replacement, Battery: step 1, image 1 of 1
    • Power down the device and make sure that it is turned off.
    • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
    • Gently twist tool clockwise until the back case pops open [this will create a small gap].
    • Slide the tool along the gap around the entire device.
  2. LG X Style Rear Facing Camera  Replacement: step 2, image 1 of 2 LG X Style Rear Facing Camera  Replacement: step 2, image 2 of 2
    • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
  3. LG X Style Rear Facing Camera  Replacement, Screen: step 3, image 1 of 2 LG X Style Rear Facing Camera  Replacement, Screen: step 3, image 2 of 2
    • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
  4. LG X Style Rear Facing Camera  Replacement: step 4, image 1 of 3 LG X Style Rear Facing Camera  Replacement: step 4, image 2 of 3 LG X Style Rear Facing Camera  Replacement: step 4, image 3 of 3
    • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
    • Slide prying tool around entire device beginning toward the top.
    • Lift off and remove the screen from the device.
  5. LG X Style Rear Facing Camera  Replacement, Rear Facing Camera: step 5, image 1 of 2 LG X Style Rear Facing Camera  Replacement, Rear Facing Camera: step 5, image 2 of 2
    • Gently use the plastic opening tool to pinch off camera connection tab from motherboard.
  6. LG X Style Rear Facing Camera  Replacement: step 6, image 1 of 1
    • With the plastic opening tool, gently lift up camera housing and remove.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 321
