LG Xenon Keyboard Replacement
  1. LG Xenon Keyboard Replacement, Back Case: step 1, image 1 of 1
    • Turn the phone so the back side is face up.
  2. LG Xenon Keyboard Replacement: step 2, image 1 of 2 LG Xenon Keyboard Replacement: step 2, image 2 of 2
    • Use your thumb to press on the small ridge at the bottom of the phone, then push upward to slide off the back casing.
  3. LG Xenon Keyboard Replacement, Battery: step 3, image 1 of 2 LG Xenon Keyboard Replacement, Battery: step 3, image 2 of 2
    • Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
  4. LG Xenon Keyboard Replacement, Motherboard: step 4, image 1 of 2 LG Xenon Keyboard Replacement, Motherboard: step 4, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
  5. LG Xenon Keyboard Replacement: step 5, image 1 of 1
    • Push a spudger or small tool under the inner edge of the back panel and gently pry upward to separate it from the main body.
  6. LG Xenon Keyboard Replacement: step 6, image 1 of 2 LG Xenon Keyboard Replacement: step 6, image 2 of 2
    • Pop off the camera, lock, and volume buttons from the side of the phone using tweezers.
  7. LG Xenon Keyboard Replacement: step 7, image 1 of 2 LG Xenon Keyboard Replacement: step 7, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the two 3mm screws, which secure the motherboard.
  8. LG Xenon Keyboard Replacement: step 8, image 1 of 2 LG Xenon Keyboard Replacement: step 8, image 2 of 2
    • Carefully lift and remove the motherboard from the main body.
    • The connector cable will still be attached to the motherboard. Any damage to the connector cable may permanently disable the phone.
  9. LG Xenon Keyboard Replacement: step 9, image 1 of 2 LG Xenon Keyboard Replacement: step 9, image 2 of 2
    • Carefully unclip the metal tab to separate the connector cable from the motherboard.
  10. LG Xenon Keyboard Replacement: step 10, image 1 of 2 LG Xenon Keyboard Replacement: step 10, image 2 of 2
    • Once the connector cable is detached from the motherboard, you have successfully removed the motherboard from the phone.
  11. LG Xenon Keyboard Replacement, Keyboard: step 11, image 1 of 1
    • Turn the motherboard over and carefully remove the keypad from the motherboard.
    • The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
Micaela Saqui
78 Reputation
7 Guides authored
Cal Poly, Team 9-41, Regan Spring 2012 Member of Cal Poly, Team 9-41, Regan Spring 2012
CPSU-REGAN-S12S9G41
5 Members
19 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 913
