LG env2 vx9100 Front Keyboard Replacement
  1. LG env2 vx9100 Front Keyboard Replacement, Battery: step 1, image 1 of 3 LG env2 vx9100 Front Keyboard Replacement, Battery: step 1, image 2 of 3 LG env2 vx9100 Front Keyboard Replacement, Battery: step 1, image 3 of 3
    • Power off the phone before disassembly to avoid electric shock or fire.
    • Place the phone face down on the table.
    • Pull down the tab below the battery with your fingernail or an opening tool.
    • Lift the battery out.
  2. LG env2 vx9100 Front Keyboard Replacement, Back Panel: step 2, image 1 of 2 LG env2 vx9100 Front Keyboard Replacement, Back Panel: step 2, image 2 of 2
    • Locate the five rubber covers on the back panel of the phone.
    • Use a metal probe to remove each rubber cover and expose the screws underneath.
  3. LG env2 vx9100 Front Keyboard Replacement: step 3, image 1 of 2 LG env2 vx9100 Front Keyboard Replacement: step 3, image 2 of 2
    • Locate the six 2.5-millimeter Phillips #00 screws on the back panel.
    • Remove all six screws with a Phillips #00 screwdriver.
  4. LG env2 vx9100 Front Keyboard Replacement: step 4, image 1 of 2 LG env2 vx9100 Front Keyboard Replacement: step 4, image 2 of 2
    • Locate the seam around the edge of the phone.
    • Insert a plastic opening tool into the seam and gently pry to release the tabs.
    • Work around the phone until all tabs are released.
    • Remove the back panel.
  5. LG env2 vx9100 Front Keyboard Replacement, Front Panel: step 5, image 1 of 2 LG env2 vx9100 Front Keyboard Replacement, Front Panel: step 5, image 2 of 2
    • Use a spudger to pry the two rubber covers out of the device.
  6. LG env2 vx9100 Front Keyboard Replacement: step 6, image 1 of 2 LG env2 vx9100 Front Keyboard Replacement: step 6, image 2 of 2
    • Use a Phillips #00 screwdriver to remove two 2.5 mm screws.
  7. LG env2 vx9100 Front Keyboard Replacement: step 7, image 1 of 2 LG env2 vx9100 Front Keyboard Replacement: step 7, image 2 of 2
    • These screws will not be visible or accessible unless the two sides of the phone are at approximately 90 degrees relative to each other.
  8. LG env2 vx9100 Front Keyboard Replacement: step 8, image 1 of 2 LG env2 vx9100 Front Keyboard Replacement: step 8, image 2 of 2
    • Insert the plastic opening tool in the crease and move it along each edge of the phone.
    • Separate the front panel from the rest of the phone.
    • Be careful not to damage the orange ribbon that connects to the motherboard through the hinge in the phone. If the ribbon is damaged, the phone will not function properly.
    • Open the phone to reveal the inside monitor.
  9. LG env2 vx9100 Front Keyboard Replacement: step 9, image 1 of 3 LG env2 vx9100 Front Keyboard Replacement: step 9, image 2 of 3 LG env2 vx9100 Front Keyboard Replacement: step 9, image 3 of 3
    • Use a Phillips #00 screwdriver to remove two 2.5mm screws.
    • Using your hands, separate the front panel from the phone by carefully pulling it straight off.
  10. LG env2 vx9100 Front Keyboard Replacement, Front Keyboard: step 10, image 1 of 2 LG env2 vx9100 Front Keyboard Replacement, Front Keyboard: step 10, image 2 of 2
    • Place the front panel so that the buttons face upwards.
    • Push on the buttons to remove the keyboard from the front cover.
2 other people completed this guide.
Reed Williston
34 Reputation
7 Guides authored
Cal Poly, Team 16-55, Forte Fall 2012 Member of Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 883
