LG env2 vx9100 Front Panel Replacement
  1. LG env2 vx9100 Front Panel Replacement, Battery: step 1, image 1 of 3 LG env2 vx9100 Front Panel Replacement, Battery: step 1, image 2 of 3 LG env2 vx9100 Front Panel Replacement, Battery: step 1, image 3 of 3
    • Power off the phone before disassembly to avoid electric shock or fire.
    • Place the phone face down on the table.
    • Pull down the tab below the battery with your fingernail or an opening tool.
    • Lift the battery out.
  2. LG env2 vx9100 Front Panel Replacement, Back Panel: step 2, image 1 of 2 LG env2 vx9100 Front Panel Replacement, Back Panel: step 2, image 2 of 2
    • Use a metal spudger to remove the five rubber covers and expose the screws underneath.
  3. LG env2 vx9100 Front Panel Replacement: step 3, image 1 of 2 LG env2 vx9100 Front Panel Replacement: step 3, image 2 of 2
    • Remove all six 2.5 mm screws with a Phillips #00 screwdriver.
  4. LG env2 vx9100 Front Panel Replacement: step 4, image 1 of 2 LG env2 vx9100 Front Panel Replacement: step 4, image 2 of 2
    • Insert a plastic opening tool into the seam and gently pry to release the tabs.
    • Work around the phone until all tabs are released.
    • Remove the back panel.
  5. LG env2 vx9100 Front Panel Replacement, Front Panel: step 5, image 1 of 2 LG env2 vx9100 Front Panel Replacement, Front Panel: step 5, image 2 of 2
    • Use a spudger to pry the two rubber covers out of the device.
  6. LG env2 vx9100 Front Panel Replacement: step 6, image 1 of 2 LG env2 vx9100 Front Panel Replacement: step 6, image 2 of 2
    • Use a Phillips #00 screwdriver to remove two 2.5 mm screws.
  7. LG env2 vx9100 Front Panel Replacement: step 7, image 1 of 2 LG env2 vx9100 Front Panel Replacement: step 7, image 2 of 2
    • These screws will not be visible or accessible unless the two sides of the phone are at approximately 90 degrees relative to each other.
  8. LG env2 vx9100 Front Panel Replacement: step 8, image 1 of 2 LG env2 vx9100 Front Panel Replacement: step 8, image 2 of 2
    • Insert the plastic opening tool in the crease and move it along each edge of the phone.
    • Separate the front panel from the rest of the phone.
    • Be careful not to damage the orange ribbon that connects to the motherboard through the hinge in the phone. If the ribbon is damaged, the phone will not function properly.
    • Open the phone to reveal the inside monitor.
  9. LG env2 vx9100 Front Panel Replacement: step 9, image 1 of 3 LG env2 vx9100 Front Panel Replacement: step 9, image 2 of 3 LG env2 vx9100 Front Panel Replacement: step 9, image 3 of 3
    • Use a Phillips #00 screwdriver to remove two 2.5mm screws.
    • Using your hands, separate the front panel from the phone by carefully pulling it straight off.
Reed Williston
34 Reputation
7 Guides authored
Cal Poly, Team 16-55, Forte Fall 2012 Member of Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,694
