LG env2 vx9100 Inside Keyboard Replacement
  1. LG env2 vx9100 Inside Keyboard Replacement, Battery: step 1, image 1 of 3 LG env2 vx9100 Inside Keyboard Replacement, Battery: step 1, image 2 of 3 LG env2 vx9100 Inside Keyboard Replacement, Battery: step 1, image 3 of 3
    • Power off the phone before disassembly to avoid electric shock or fire.
    • Place the phone face down on the table.
    • Pull down the tab below the battery with your fingernail or an opening tool.
    • Lift the battery out.
  2. LG env2 vx9100 Inside Keyboard Replacement, Back Panel: step 2, image 1 of 2 LG env2 vx9100 Inside Keyboard Replacement, Back Panel: step 2, image 2 of 2
    • Locate the five rubber covers on the back panel of the phone.
    • Use a metal probe to remove each rubber cover and expose the screws underneath.
  3. LG env2 vx9100 Inside Keyboard Replacement: step 3, image 1 of 2 LG env2 vx9100 Inside Keyboard Replacement: step 3, image 2 of 2
    • Locate the six 2.5-millimeter Phillips #00 screws on the back panel.
    • Remove all six screws with a Phillips #00 screwdriver.
  4. LG env2 vx9100 Inside Keyboard Replacement: step 4, image 1 of 2 LG env2 vx9100 Inside Keyboard Replacement: step 4, image 2 of 2
    • Locate the seam around the edge of the phone.
    • Insert a plastic opening tool into the seam and gently pry to release the tabs.
    • Work around the phone until all tabs are released.
    • Remove the back panel.
  5. LG env2 vx9100 Inside Keyboard Replacement, Inside Keyboard: step 5, image 1 of 3 LG env2 vx9100 Inside Keyboard Replacement, Inside Keyboard: step 5, image 2 of 3 LG env2 vx9100 Inside Keyboard Replacement, Inside Keyboard: step 5, image 3 of 3
    • Locate the silver strip - closest to the bottom hinge of the phone - connected to the logic board.
    • Wedge the plastic opening tool in between the silver strip and the logic board.
    • Apply upward pressure with the plastic opening tool to separate the silver strip from the logic board.
  6. LG env2 vx9100 Inside Keyboard Replacement: step 6, image 1 of 2 LG env2 vx9100 Inside Keyboard Replacement: step 6, image 2 of 2
    • Wedge the plastic opening tool in between the logic board and the phone.
    • Carefully pry these two pieces apart by going around the perimeter of the phone to separate the logic board from the phone.
  7. LG env2 vx9100 Inside Keyboard Replacement: step 7, image 1 of 2 LG env2 vx9100 Inside Keyboard Replacement: step 7, image 2 of 2
    • Locate the back of the inside keyboard.
    • Take out the inside keyboard. By using your fingernails to pull one of the corners up, you can snap this piece out of its encasement.
    • Replace the keyboard by snapping the new keyboard into place, and begin to follow the steps in reverse to reassemble the device.
Reed Williston
34 Reputation
7 Guides authored
Cal Poly, Team 16-55, Forte Fall 2012 Member of Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 8
All Time: 964
