LG-A275 Speaker Replacement
Nathanael Knight
Nathanael Knight and one other contributor
Last updated on May 25, 2018
15 minutes
Moderate
Introduction
Go to step 1
In this guide, you will see how to take apart the LG-A275 in order to replace the phone's speaker.
Tools
  1. LG-A275 Speaker Replacement, Battery: step 1, image 1 of 2 LG-A275 Speaker Replacement, Battery: step 1, image 2 of 2
    • Turn the phone upside down so that the bottom of the back is facing you.
  2. LG-A275 Speaker Replacement, Remove cover: step 2, image 1 of 2 LG-A275 Speaker Replacement, Remove cover: step 2, image 2 of 2
    • Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
  3. LG-A275 Speaker Replacement: step 3, image 1 of 1
    • Gently remove the battery from the device.
  4. LG-A275 Speaker Replacement, Speaker: step 4, image 1 of 3 LG-A275 Speaker Replacement, Speaker: step 4, image 2 of 3 LG-A275 Speaker Replacement, Speaker: step 4, image 3 of 3
    • Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
    • Be careful when using the opening tool not to use brute force and potentially break the fragile phone plastics.
  5. LG-A275 Speaker Replacement: step 5, image 1 of 3 LG-A275 Speaker Replacement: step 5, image 2 of 3 LG-A275 Speaker Replacement: step 5, image 3 of 3
    • After separating the front and back components of the phone, proceed to take off the motherboard. This can be done by releasing the plastic clamps on the corners and edges of the plastic front using your fingernail.
    • Be careful when doing this to avoid breaking the phone plastics, it should release easily.
  6. LG-A275 Speaker Replacement: step 6, image 1 of 3 LG-A275 Speaker Replacement: step 6, image 2 of 3 LG-A275 Speaker Replacement: step 6, image 3 of 3
    • Lastly remove the speaker using the plastic opening tool.
Nathanael Knight
181 Reputation
2 Guides authored
IUPUI, Team S3-G1, Harley Spring 2018 Member of IUPUI, Team S3-G1, Harley Spring 2018
IUPUI-HARLEY-S18S3G1
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 247
